Where do you guys get your Dow 55 or 111 locally?
Thank you.
Schleprock
McMaster Carr. I have one in my region so it's like having a local hardware store. I order something this afternoon and it shows up on my doorstep the next day before lunch. If you're using it for o-rings, you want 111 or 112. 55 is not silicone friendly and its twice the price.
Kevin L '86 Carrera "Larry" |
Yeah, looks like I'll have to order it.
I found it in a local motorcycle shop. They also had the 3bond I was looking for. They were less than 2 miles from the house and I figured I would give them a try. Glad that I did.
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
The Dude abides...
Steve '03 Carrera 4S |
Try not, Do or Do not
"Dow Corning® 55 O-Ring Lubricant is a soft silicone-based grease, slightly swells rubber for better sealing, oxidation resistant and serviceable over a wide temperature range. Used for dynamic lubrication and sealing between rubber and metal parts in pneumatic valves. Typical applications are found within the aircraft, automotive, paintball and other industries."
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
McMaster Carr does not deliver, but UPS does.
Schleprock
Good to know Henry's had great success with 55. Those with much less experience are probably better off erring on the side of caution, since all silicone is not the same and most people don't know what type of material makes up their o-rings? So I said not silicone friendy just to be safe.
http://www4.dowcorning.com/DataFiles/090007c88033c335.pdf COMPATIBILITY Molykote 55 O-Ring Grease has been shown to swell natural rubber. However, compatibility of the lubricant may vary with the plasticizer content of specific materials (especially elastomers). Small-scale compatibility testing should be conducted prior to the use of this product in any application. Molykote 55 O-Ring Grease should not be used with the following materials unless thoroughly tested for your specific application: Silicone rubber (SR) Polycarbonate (PC) Acrylonitrile-butadienestyrene (ABS) Liquid oxygen (or other strong oxidizers)
For what it's worth, I originally used the government-spec 55 from Henry's sealant kit. There was enough for one only application on each o-ring (at least the way I was smearing it on), and unfortunately I find myself having to split and assemble the case a second time.
I would like to recommend he create a #$%@-up kit that contains a little extra 55 for the novice and inept among us...
