2.2L U-Boat engine
I bought an engine, Case # 901.101.102.3R , Serial # *6119625* around 12 years ago seized as tight as a drum . I had planned to learn about the Porsche 6 cylinder engine with this as low cost fodder, since I make mistakes regularly. Anyhow, I just never got to it until a couple of weeks ago. Going by the numbers, I pulled the right cam carrier and heads 4,5 and 6 with some difficulty. When i carefully got them off I found cylinder 4 full of an oily rusty mess (trying to get images downloaded) and the piston stuck I guess the good news is the crank and internal components appear to be okay. Here's my question... What's the best way to get the piston out of the cylinder? I don't want to start whacking things unlessa absolutely necessary. Also, am I correct in thinking this engine is out of a 71 911 Sportomatic?
Old 12-10-2012, 04:59 PM
911 2.2 T targa
If you point the cylinder upward you can poor some Coca Cola in it. Regular so no diet stuff and leave it in for day or so. I have heard that this does the trick.
Old 12-12-2012, 01:39 AM
On frozen motors where the rings have rusted to the cylinders, I usually sacrifice the cylinders. I cut a deep groove in the cylinder with a cutoff wheel. Then I use a chisel to split them open. This frees them from the the piston and allows them to be removed and tossed in the recycle bin.
My experience is that repeated penetrant soaking and heat applicatio usually does not work
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-12-2012, 05:10 AM
Thank you both for your replies... It'll going to be a long process, but I'm sure I'll get it right in the end. I've heard of the Coke remedy and will put it into play if needed. I have to assume that the cylinder is toast anyway, so sacrificing it will work too.
Question... Will the piston (assuming it spec's okay) be able to be mated to another cylinder?
Thanks again.
Old 12-12-2012, 03:27 PM
Party Member
viejopatron's Avatar
If you're not in a hurry I would repeatably apply penetrant, low heat and light impacts and try to save as much as you can.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 12-16-2012, 07:53 AM
Hell Belcho
Nostril Cheese's Avatar
Aerokroil, heat. Repeat as needed.
Old 12-16-2012, 05:22 PM
djpateman's Avatar
You are correct, it is a type 911/06 "Rest of the World" Sporto.
Is the other side of the case also 3R?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-19-2012, 05:31 PM
Success! Not much heat necessary. I let penetrating oil do some of the work although I really don't think it got past the first ring. To answer your question, djpateman, yes, the case is marked 3R on both sides. Now I get to develop my rebuild plan, yay! Thanks again to all.
Old 12-20-2012, 05:06 AM
porschetub's Avatar
Was the motor stored outside ?,looks like water damage,shame looks like you be after a replacement b+p to start with.
Good to see you have it freed but I reckon you are in for some work on this motor,good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 12-29-2012, 11:47 PM
