OK. But pulled studs with modern methods are no longer a problem. A long life 2.7 is very achievable and repeatable using the methods the establishment has developed over the years. From what I'm reading you've conceded that after all this you are primarily banking on long cylinder life from using synthetic oil over the plethora of modern cylinder treatments with a proven track record. Really? The only thing at all that I can see different is that perhaps you've somewhat alleviated the cooling and detonation issue through the use of ceramic coatings, unconventional valve covers and a few other tidbits. Even if the dyno shows you are building respectable power and doing it on 90 degree days without issue that still doesn't change the fact that none of that is a problem if you use standard cylinders to begin with. So all that at what cost? You are welcome to throw as much money as you want at your own project. But assuming people start to adopt your build approach are they actually saving any money? Gaining any life expectancy to their motor? more HP? What is the advantage that you have given us over the establishment? You know I've gone my own way in life more than once too and had success. But I was always respectful of those that told me it should not or could not be done. Sometimes I was vindicated, more often I was not. But it would never have been any fun to me to share my success if I had been a complete dick to every one of those mentors along the way.
Ted 1972 911T (currently not so speedy ![]() 1998 A4 1.8Tq 2003 GMC Savanna 2004 A6 Avant Last edited by speedy72911t; 06-21-2013 at 12:47 PM.. |
Straight shooter
200 more miles today in the heat and no detonation even when stuck in traffic before crossing the mountain gaps.
What do I want for other readers that visit this thread? I'm glad you ask if there is any impression that this is a self-righteous ego pump. Here's what I would like for people to take away... of course they can take it or leave it and those that leave it are entitled to that freedom. I wish them all the luck with their endeavors even if it's my personal opinion that their heads are squarely up their asses. Free information, honest results and feedback on what I did here. Completely unfiltered. 1) Have confidence in your own abilities and your own data. 2) Just because someone, even a smart someone, tells you something can't be done doesn't make it so. 3) Imagination is sometimes more valuable than experience. 4) Don't be afraid to stand up for yourself and your plans; you don't have to take crap from anyone if you know what you're doing. 5) See your plans through while being adaptable. 6) Alternatives exist. That's it. Quote:
JE pistons - $900 Cylinders - $650 including machine work Install materials including sealants/gaskets - $300 4 x Valve Covers including sinks and mil spec anodize - $850 Money saving... I think so compared to the Mahle RS costs. Definitely saving if you have a case failure with the aluminum stuff swelling with heat. Performance gain? Unknown at this time. I can only say what my seat of pants says compared to the Mahle RS stuff and it's an increase. Considering I've heard again and again how HP for the magnesium case is limited to ensure life expectancy, I have to wonder how the folks stating this information distinguish between that limitation and what they thought Porsche did as far as limiting power with the iron cylinder. Is it possible you could actually extract more hp reliably from a cast iron cylinder because it is not yanking on the case the same as the aluminum cylinder that is hp limited due to thermal expansion? Maybe so but I certainly don't think it's guaranteed. I don't expect to answer that question with my silly little street car but the question is posed now. Quote:
I do appreciate many folks that offered guidance for dealing with the sticks in the mud and also the helpful tips offered while I shared my assembly steps. Many thanks to those kind souls. There are some great guys in this group and some not-so-great guys. That's life, I'm used to it.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Straight shooter
Try not, Do or Do not
What, no heat wrap?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Straight shooter
Wrap isn't on yet. I have the roll and plan to put it on sometime this week as I'm adjusting the valves and have it up in the air. We'll have to see if it helps or traps heat in the pipes that go back into the heads.
Half way through the 5th tank of gas after doing NEK around to Champlain Islands this past weekend. Running water remover in each tank. Removed a diode found in the trigger wire at suggestion of my brother who has many years of MSD experience with race teams and hot/cold starts have improved. Took in the races and local color on Thursday. ![]() ![]() As much as I enjoy the engine noises the fiance would prefer I fix the stereo. Tried to take in a drive-in movie in St. Albans on Sunday and was denied... ![]() ![]() Popped it up last night and drained all oil/removed covers and adjusted 2/12 valves before calling it a night. Checking the remaining as time allows in the evenings. This is the second oil change since the top end rebuild. ![]()
Straight shooter
Valves all adjusted. Wrapped.
![]() ![]() See you out there... ![]()
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 07-01-2013 at 07:07 AM.. |
I'm glad to see you wrapping the exhaust. I want you to have every chance at success given the limited potential of this build.
Racer
Then I said, I'm glad he wrapped it because I want him to succeed. Any impartial jurist would concede that cast iron cylinders offer limits to heat dissipation hence the term " limited potential" I guess I should have said "limited potential for cooling".
Straight shooter
Banned
Racer
Scott |
Straight shooter
Cold run with HD audio/video. Pardon the loose belt. Piston slap? Ummm....
https://www.youtube.com/watch?v=14GjQjVVgms Edited to fix video link.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 07-22-2013 at 08:32 AM.. |
Straight shooter
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 07-23-2013 at 05:45 PM.. |
Even out of context I'll stand behind every one of those statements.
What else do you have?
Racer
Scott |
This whole thread reminds me of the old time flame wars I used to see between the younger people on the net (this was way back!).
It goes on forever. Andrew...I can not hear any "slap" you might be concerned about..it sounds like a good running engine. Any build that gets you back out on the road with one of these fine automobiles is a good build. I hope the cylinder/piston combo holds up for a long time...I look forward to more info as the miles go by. Bob
Bob Hutson |
Ladies and Gentlemen,
The Engine Rebuilding Forum strives to be like Medical School sometimes: we learn, we post our work for "peer review" and we teach others. Criticism is OK, in fact it's welcomed, so long as it can remain free of personal attacks. We're not concerned with fixing the blame on a particular user, only with fixing the problem; which at the moment is that users are concerned that the level of personal flaming is interfering with our mission above. Let's not let that happen, let's keep this forum a good place to learn, show and teach. Thank you very much for your time.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Author of "101 Projects"
I haven't had time to read this thread all the way through, but I do not wish to close it. Everyone needs to step off and stop being like they are.
If this silliness continues, I will close the thread. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Straight shooter
Sorry for the mess and thank you for the moderation.
That was my thought as well. There is no slap even cold and I wanted to share the evidence with the readers here. This was called out as a downfall for running forged pistons and it has proven false in the application here. The bore was honed to .004" clearance to the JE piston. If I were to do this again, I would order the JE pistons custom sized (very minor change relative to their off the shelf that I used) to match the bore rather than having the bore honed out. The cost out of pocket and hassle would be far less. I am following the timeless rule of taking care to warm the engine fully before loading it heavily. I'm expecting a long life from this engine with the synthetic oil once that time comes. Given the amount of oil with a front cooler, I may use my magnetic sump heater once the weather cools to warm the tank before start-up. The less running when cold and loose, the better engines will wear if all else is equal.
Thread Tools | |
Rate This Thread | |
