Anyone know of a speciality shop that makes timing chains or modifies them?
I am trying to help a good friend of mine out. He is looking for someone that makes custom timing chains or could modify his existing timing chain with a master link. Here is the message he forwarded me, and a picture of what he is dealing with. I would really like to find an answer for him if I could. He has helped me out on my race car ALOT. Here is what he sent me.....
I have a 2002 Porsche Boxster S 3.2 that suffered from a broken timing chain. What I wanted to find out is if there is a way that a timing chain could have a master link or connection link added. I have found chains for some of the older Porsches that use a connecting link but no one offers one for this engine at this time. With a master link i could replace the chain without having to split the cases.
Old 04-14-2013, 09:18 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Buy bulk chain from a supplier (McMaster-Carr?) with some master links...and make your own custom units.
Chains come in various sizes and configurations...some are listed as "heavy duty"...and some even have O-rings in them for more permanent lubrication.
What you are looking for is one that has double links...no O-rings...and the heaviest duty that will fit.
Be advised...the really heavy duty ones have thicker side plates..and some have no figure "8" pattern to them....more of a straight side link.
I would think the straight type might be better in the long run...because they do not stretch as quickly...and they would run over the tentioner bars better.
Bob
Bob Hutson
Old 04-14-2013, 09:33 AM
that looks a lot like an older 911 chain. if the dimensions are the same, try a 911 chain link kit. or just buy one and hold it up to your chain and see if it might work. just a matter of grinding off the ends of one link and sliding it off.
206 637 4071
Old 04-15-2013, 01:05 PM
Walt Fricke's Avatar
I suspect McMaster and the like sell just the master links in various flavors, as well as bulk chain.
Old 04-16-2013, 04:57 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Gotta be lots of Boxster/996 chains lying around that could be used for experimentation. Find a used/free 996 chain and do some test work on it with the 911 master link kit
Porsche 911 & Carrera Cam Towers & Timing Chains - Page 4
Both chains are made by IWIS so I suspect there's some ability to interchange links?
Porsche Boxster Cam Towers & Timing Chains - Page 1
Kevin L
'86 Carrera "Larry"
Old 04-17-2013, 08:06 AM
