Firing Order for 87
A little confused by the description in Waynes book so I just want to confirm the firing order
1-6-2-4-3-5 on an 87 3.3 turbo, (note the book says its different for various years) and the distributer therefore moves counter clockwise? thanks in advance
David |
Irrationally exuberant
I thought the firing order was the same for all years?
The distributor turns "backwards" (CCW) on an SC compared to all the other motors. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Try not, Do or Do not
The distributors turn Counter Clock Wise for 911SCs 78 to 83 and 930 3.3 turbo from 78 to 89.
The firing order is the same for all 911 based engines. 1-6-2-4-3-5
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks for the clarification Henry.
David |
Author of "101 Projects"
Right - firing order is the same, distributor turns, and is wired, backwards...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
What does Wayne mean by 'wired backwards?' |
Well, the firing order is 1-6-2-4-3-5. Cylinder number one will always be the one nearest the notch, and cylinder number 4 will always be 180 degrees oposite from it. However, one will go 1-6-2-4-3-5 and other will go 1-5-3-4-2-6. Clockwise vs. counter-clockwise, or backwards. I explain this on page 190. -Wayne
Thanks Wayne. I'll check my book.
NO, it will stil go 1-6-2-4-3-5 as the spark plug wires are installed in that position, any other firing order would require new cams.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
You guys are both right, just not very clear. I'll give it a try.
On 78-83 911 SCs & 78-89 930 the ditr. turns counter clock wise (ccw). This means you start at the number one plug wire, generally marked on the dist. with a small line and go ccw 1-6-2-4-3-5. On all other Porsche 911 dist. you start at the number one plug and go clock wise 1-6-2-4-3-5. I hope this clears things up.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-11-2004 at 08:23 PM.. |
See the book - a picture is worth a thousand words...
-Wayne
I guess I'll have to use my experience and hope for the best.
Brorag
ouch!
Counter clockwise, clockwise,,
im working out firing on a 1977 930, with the above info does this mean that a 77 is clockwise from number one?? can of worms here
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
BTW for this reason all camshafts can be used in principle for each engine...
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 05-07-2013 at 01:57 PM.. |
Robbbyg,
Just turn the engine over by hand and see which way the rotor turns. -Andy
72 Carrera RS replica, Spec 911 racer |
A 77 930 turns clockwise
No left turn un stoned |
Anyone know why they did this? CW for some CCW for others? I only ask because I'm a collector of random facts
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD 10 997.2 Cab - Speed Yellow 83 SC Cab - Guards Red [SOLD] 17 NSX - Nouvelle Blue |
