Twin Plug, bottom plug question
Other than using the ARP head nuts, is there any way/tool available to install the bottom plugs on a twin plug head? The stock lower head nut protrudes just enough to block the plug socket! These heads were already drilled and tapped for 14mm plugs (top and bottom) when I bought them. I am using the NGK BPR6ES plugs, at least for the initial startup.
Thanks,
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Typing error
That should be Raceware head nuts, not ARP. My bad!
Just went through this, you can use standard VW air cooled engine head nuts on these head studs, the plug removal tool or a plug socket then fits. I am using the same plugs you are.
I have to credit Steve at Rennsport Systems for this, he is the one who answered the same question for me. W
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
Another way.........
Try not, Do or Do not
We use NGK BKR 6 EKUB or BOSCH FGR 6 KQE.
These plugs have 14mm thread but use a 5/8' or 16mm socket. Of course with Supertec head stud plug clearance is never an issue.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Aw come on...........
I know that the Supertec head studs and associated hardware is tops. And thanks for the tip on the other spark plugs. But, cut me some slack here, I at least bought and am using a set of the Supertec engine air diverter tins!
Hey Fred, you can have all the "slack" you need. The statement was designed to inform those who don't have your knowledge.
I just noticed a missing nut, no "slack" here. ![]() Cheers
Missing nut......
Thanks for the heads up. I found that missing nut right after this picture was taken! Actually, I appreciate all of the input that is available from this board! What an incredible wealth of knowledge!
