fred cook's Avatar
Twin Plug, bottom plug question
Other than using the ARP head nuts, is there any way/tool available to install the bottom plugs on a twin plug head? The stock lower head nut protrudes just enough to block the plug socket! These heads were already drilled and tapped for 14mm plugs (top and bottom) when I bought them. I am using the NGK BPR6ES plugs, at least for the initial startup.
Thanks,
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-11-2013, 06:33 AM
fred cook's Avatar
Typing error
That should be Raceware head nuts, not ARP. My bad!
FEC3
Old 06-11-2013, 06:45 AM
Just went through this, you can use standard VW air cooled engine head nuts on these head studs, the plug removal tool or a plug socket then fits. I am using the same plugs you are.
I have to credit Steve at Rennsport Systems for this, he is the one who answered the same question for me.
W
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 06-11-2013, 08:22 AM
fred cook's Avatar
Another way.........
W
I just finished fixing the problem another way. The interference between the head nut and the plug socket is very small. I removed each of the head nuts that were in the way and ground a small 45 degree bevel (approx. 3mm x 3mm) on the top end of the nut. I did not take off enough metal to compromise the integrity of the head nut, just enough to allow the plug socket to slide by. I did each, one at a time and retorqued the nut before moving on to the next one. The standard plug socket now just barely slides by the offending head nut, but it works!
FEC3
Old 06-11-2013, 09:11 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We use NGK BKR 6 EKUB or BOSCH FGR 6 KQE.
These plugs have 14mm thread but use a 5/8' or 16mm socket.
Of course with Supertec head stud plug clearance is never an issue.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-11-2013, 09:58 AM
fred cook's Avatar
Aw come on...........
Henry,
I know that the Supertec head studs and associated hardware is tops. And thanks for the tip on the other spark plugs. But, cut me some slack here, I at least bought and am using a set of the Supertec engine air diverter tins!
FEC3
Old 06-11-2013, 10:04 AM
Hey Fred, you can have all the "slack" you need. The statement was designed to inform those who don't have your knowledge.
I just noticed a missing nut, no "slack" here.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 06-11-2013, 10:20 AM
fred cook's Avatar
Missing nut......
Cheers
Thanks for the heads up. I found that missing nut right after this picture was taken! Actually, I appreciate all of the input that is available from this board! What an incredible wealth of knowledge!
FEC3
Old 06-11-2013, 10:57 AM
