LinkBack | Thread Tools | Rate Thread |
Schleprock
Understood the Mobil Vtwin is intended for air/oil cooled use. But the one thought I had, is there any downside to the dual usage it provides- it also serves the motorcycle transmission and wet clutch?
Kevin L '86 Carrera "Larry" |
I would run the engine, set up a baseline tune then drain the oil. About 2 hrs of run time in total. Then Delo or Brad Penn...I'll discuss Henry's Brad Penn finding with him as I have not heard about it. The only critical area for oil I have seen is the Cams/rockers. The majority of issues been reground rocker arms that are not parallel.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
Banned
This question usually gets the same type responses that all oil related questions get - some say "yes" and some say "no". Based on my personal experiences with using motorcycle oil in non-wet clutch engines (Ducati 748R which I endurance raced for three season and my 930 - both engines which I overhauled at one point), the answer is no, there is no downside. Obviously, mine is a very limited experience base, however.
Kevin, My understanding is that the V-twin Mobil 1 lacks the friction modifiers present in the normal Mobil 1 for cars. So, without the modifiers, I guess you could expect a slight degradation in fuel economy. The normal Mobil 1 in the 15W50 viscosity still has the elevated ZDDP that our flat tappet motors need. Or, if you go to Mobil 1 Racing oil, all the viscosities have the elevated ZDDP levels.
Ernie 98 993 C2S - Arena Red/Beige 76 914/6 3.2 Conversion - Estorill Blue/Coral Red |
Regualr Mobil 1 15 /50 has 1350 ppm Zinc
V-twin has 1750 ppm Zinc Brad Penn has between 1200- 1500 http://www.penngrade1.com/Zinc.aspx Flat tappet engines need 1400-1500 ppm zinc Chris Last edited by cmcfaul; 07-26-2013 at 05:28 AM.. |
Chris, You are generally accurate on your comments on zinc. What needs to be added is that most oil suppliers have cut the ZDDP levels from 1300-1500 ppm to levels around 650 - 750 which appears to be unsatisfactory for our flat tappet motors. If you are in the market for 15/50 oil, then I question that the Mobil 1 formulation isn't a good choice, even though it does not quite meet your criteria of 1400 ppm for zinc. In reality, whether you run Mobil 1, Mobil V-twin, Motul, Joe Gibbs, Total or some other brands I may have left out, it will come down to availability and cost. All these oils are expensive and may not be readily available. And, all thanks to the USEPA for creating this dilemma for people with older cars.
Schleprock
Thanks for the tips on the V-twin formulation. Sorry for the sidetrack but I thought i'd ask since the mention of it came up.
I'm going with the Chevron Delo 400 for my motor when it's done. If it's good enough for Henry, good enough for me! Already got two boxes (6 gallons) on hand from Costco!!!
Thanks for the tips guys. Just got six 1 gallon Delo 400 30w jugs from Amazon. Let the engine break in begin.
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Here are the numbers. Note that all the break in oils have triple the zinc.
1. 10W30 Lucas Racing Only synthetic = 106,505 psi zinc = 2642 ppm phos = 3489 ppm ZDDP= 3000 ppm NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. 2. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi zinc = 1669 ppm phos = 1518 ppm ZDDP = 1500 ppm NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use. 3. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi zinc = 1472 ppm phos = 1544 ppm ZDDP = 1500 ppm 4. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi zinc = 1180 ppm phos = 1112 ppm ZDDP = 1100 ppm 5. 30 wt Red Line Race Oil synthetic = 96,470 psi zinc = 2207 ppm phos = 2052 ppm ZDDP = 2100 ppm NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. 6. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi zinc = 1431 ppm phos = 1441 ppm ZDDP = 1400 ppm 7. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi zinc = 1221 ppm phos = 955 ppm ZDDP = 1000 ppm 8. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi zinc = 1247 ppm phos = 1137 ppm ZDDP = 1100 ppm 9. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi zinc = 1615 ppm phos = 1551 ppm ZDDP = 1500 ppm 10. 5W30 Lucas API SM synthetic = 76,584 psi zinc = 1134 ppm phos = 666 ppm ZDDP = 900 ppm 11. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi zinc = 1252 ppm phos = 1197 ppm ZDDP = 1200 ppm 12. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi zinc = 1421 ppm phos = 1338 ppm ZDDP = 1300 ppm 13. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi zinc = 1211 ppm phos = 1168 ppm ZDDP = 1100 ppm 14. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi zinc = 1519 ppm phos = 1139 ppm ZDDP = 1300 ppm 15. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi zinc = 1297 ppm phos = 1944 ppm ZDDP = 1600 ppm 16. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi zinc = 1325ppm phos = 1234 ppm ZDDP = 1200 ppm 17. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi zinc = 1454 ppm phos = 1062 ppm ZDDP = 1200 ppm 18. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi zinc = 1621 ppm phos = 1437 ppm ZDDP = 1500 ppm 19. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi zinc = 1171 ppm phos = 1186 ppm ZDDP = 1100 ppm 20. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi zinc = 1557 ppm phos = 1651 ppm ZDDP = 1600 ppm 21. 15W50 Mobil 1, API SN synthetic = 70,235 psi zinc = 1133 ppm phos = 1,168 ppm ZDDP = 1100 ppm 22. 30wt Edelbrock Break-In Oil conventional = 69,160 psi zinc = 1545 ppm phos = 1465 ppm ZDDP = 1500 ppm 23. 10W40 Edelbrock synthetic = 68,603 psi zinc = 1193 ppm phos = 1146 ppm ZDDP = 100 ppm 24. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi zinc = 1441 ppm phos = 1234 ppm ZDDP = 1300 ppm 25. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi zinc = 1774 ppm phos = 1347 ppm ZDDP = 1500 ppm 26. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi zinc = 1154 ppm phos = 1075 ppm ZDDP = 1100 ppm 27. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi zinc = 1765 ppm phos = 2468 ppm ZDDP = 2100 ppm 28. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi zinc = 2436 ppm (up 1848 ppm) phos = 2053 ppm (up 1356 ppm) ZDDP = 2200 ppm The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 29. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi zinc = 1170 ppm phos = 1039 ppm ZDDP = 1100 ppm 30. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi zinc = 2116 ppm phos = 1855 ppm ZDDP = 1900 ppm 31. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi zinc = 1673 ppm phos = 1114 ppm ZDDP = 1300 ppm 32. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi zinc = 1456 ppm phos = 1150 ppm ZDDP = 1300 ppm 33. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi zinc = 2711 ppm (up 1848 ppm) phos = 2172 ppm (up 1356 ppm) ZDDP = 2400 ppm The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 34. 10W40 Summit Racing Premium Racing Oil, API SL conventional = 59,483 psi zinc = 1764 ppm phos = 1974 ppm Claimed ZDDP level on the bottle = 1800 ppm NOTE: Summit discontinued this line of oil, as of spring of 2013. 35. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi zinc = 2955 ppm (up 1848 ppm) phos = 2114 ppm (up 1356 ppm) ZDDP = 2500 ppm The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 36. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi zinc = 1515 ppm (up 573 ppm) phos = 1334 ppm (up 517 ppm) ZDDP = 1400 ppm The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 37. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi zinc = 3004 ppm phos = 2613 ppm ZDDP = 2800 ppm 38. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi zinc = 1565 ppm (up 573 ppm) phos = 1277 ppm (up 517 ppm) ZDDP = 1400 ppm The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 39. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi zinc = 1680 ppm (up 573 ppm) phos = 1275 ppm (up 517 ppm) ZDDP = 1400 ppm The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware. 40. 30wt Lucas Break-In Oil conventional = 49,455 psi zinc = 4483 ppm phos = 3660 ppm ZDDP = 4000 ppm |
The Mobil 1 V twin stuff is $14/ qt expensive. I usually mail order it through Amazon. Some times it goes on sale locally.
A real V-twin has the transmission and clutch separate from the engine (attached by a fat belt). I question if the Mobil V-twin oil is designed for a wet clutch environment. Chris |
This could quickly morph into another 50 page oil thread, so let's keep this topic to "break-in lubes".
GM's EOS additive (now marketed as AC Delco Assembly Lube) is widely used on engines, for break-in as well as long term. Here's some discussion about it: E.O.S (Engine Oil Supplement) | Oil Additives | Bob Is The Oil Guy Sherwood |
So should one conclude from post 50 that the Lucas 30wt is the best oil for break-in due to the very high concentrations of ZN, Ph and ZDDP?
Just curious where you got all the data from post #50? Also how was it determined?
Thanks, Paul 1979 SC "A man of many projects and too many hobbies" |
Under the radar
What about this stuff?
I believe Porsche,AMG,Corvette and etc use Mobil 1 from the get go. I have disassembled quite a few air cooled 911 engines and have yet found any tappets (my MG has 8 my 6 has 0). The 20 min cam break in? The main reason is flat tappet engines need the oil splash from the crankshaft to lube the cam.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Senior Advisor
![]() get this, done
08 Cayenne Turbo |
break in oil.
Hi,I have always used Valvoline non-detergent straight 30W for the first 500 miles.Then do your leakdown te full st to determine ring seatage.No full throttle at first 500 miles.
Henry, My mechanic used Valvoline VR-1 20/50 for break in. Was told to change after 1,000 miles. Have not put any miles on new rebuilt yet, only been starting for 30 min at a time while I do my brake upgrade and bushings replacement. Was told it would be fine to stay with the VR-1 20/50, but should I go to the Delo 400 SAE30 after the 1,000 miles?
