Closed Thread
Straight shooter
Lapkritis's Avatar
Originally Posted by johnman001 View Post
Which flavor? I use Krytox 226 on bearings. It is expensive $150+ for a cartridge, but it does work well in certain applications. It is Fluorinated grease.
It is good for around 500°F, but I prefer o-ring grease for o-rings.
I believe in using whatever works for you.
GPL 207 is the preferred flavor. I also use this on the oil return tube, distributor, oil cooler and other rubber ring seals. There are many forms of Krytox out there with various properties... this one is suitable.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 08-07-2013, 09:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #21 (permalink)
Timely thread for me. I haven't really started assembly yet on my '84 3.2l but I checked the case last night and I only have chamfers on one half of the case as well. I ordered the tool from McMasterCarr and will take care of that before I assemble.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 08-08-2013, 10:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #22 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
We use the Dow 55 for two main reasons.
First, the Dow is a Phenyl-methyl silicone grease formulated for O-rings with properties that add a slight seal swell for increased sealing of rubber (including synthetic rubbers) to metal surfaces.
Second, silicone based products like Dow 55 resists the capillary action or wicking that can occur when white grease is used to seal petroleum based oil products.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-08-2013, 10:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #23 (permalink)
Straight shooter
Lapkritis's Avatar
Henry,
Are you using this Dow Corning 55 Molykote?
http://www.dowcorning.com/applications/search/default.aspx?R=392EN
I know they have different flavors but see this carries a relatively low temp rating. Would like to compare to the Krytox specs.
Old 08-08-2013, 11:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #24 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Dow 55 in a 5.3 oz. tube is on sale at Grainger for $6 on clearance. And then newgrainger.com opens and it's gone.............
Kevin L
'86 Carrera "Larry"
Old 08-08-2013, 11:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #25 (permalink)
Originally Posted by Lapkritis View Post
Henry,
MOLYKOTE® 55 O-RING GREASE
No, we aren't using commercially available Dow 55 Molycote. We're using a mil spec product directly from military suppliers.
As to your question: what specs do you believe Krytox has that are important to this application? I'm wondering what function you think a lubricant in this application (o-ring that seal engine oil) performs?
That question was awkward so put another way: why are we (engine builders) putting anything on an o-ring?
Henry Schmidt
Ph: 760-728-3062
Old 08-08-2013, 03:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #26 (permalink)
Straight shooter
Lapkritis's Avatar
I was going to put the spec sheets side by side. Not commercially available you say but yet you sell it making it... commercially available. Is that right?
Old 08-08-2013, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #27 (permalink)
johnman001's Avatar
My answer to "why are we (engine builders) putting anything on an o-ring?" is:
To keep the o-ring from becoming compromised during installation. This would include ripping, tearing, or pinching the o-ring when assembling the parts. The lubricant allows the o-ring to move instead of stick on the surgically clean dry surfaces that we have prepared prior to assembly. Without lube, it would be all too easy to damage the o-rings and prevent them from functioning in their intended purpose (to seal oil in and dirt out).
just my $0.02 (like I said before, use what works best for you. The opinions here are just that, opinions, and your mileage may vary.)
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 08-08-2013, 04:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #28 (permalink)
Why so combative?
The truth is, I don't sell it. I buy it in large quantity container that makes selling it impracticable. Much like most of the products I make, I made them because I needed them for my projects.
I needed a high quality o-ring lubricant so I sourced the best I could find for the shop. It works well so a add a small amount (literally a little baggie) to my sealing kit as a favor.
Johnman: You are absolutely correct "To keep the o-ring from becoming compromised during installation". After the o-ring has seated, the lubricant has done it's job and any product that can cause a capillary action or wicking is counter productive. That is why we avoid white grease and petroleum products in these applications.
Henry Schmidt
Ph: 760-728-3062
Old 08-08-2013, 05:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #29 (permalink)
Straight shooter
Lapkritis's Avatar
I'm not combative, but I would like to compare the materials by the data sheets. Why aren't you forthcoming? Just curious.
Old 08-08-2013, 06:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #30 (permalink)
safe's Avatar
I used Dow Corning Molycote 111 (because it was the o-ring grease I had) on my ongoing rebuild for the o-rings. That wasn't a mistake I hope?
Magnus
Old 08-09-2013, 03:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #31 (permalink)
No worries Magnus, Dow 111 is primarily a Silicone-based compound that resists wicking and has been used by many people on this forum with success.
Henry Schmidt
Ph: 760-728-3062
Old 08-09-2013, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #32 (permalink)
safe's Avatar
Thanks, good to hear!
They did go in quite smooth.
Magnus
Old 08-09-2013, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #33 (permalink)
Free minder
Aurel's Avatar
I used the sealing kit from Henry with the green viton O-rings and the Dow 55. Unfortunately I had the through bolts on the wrong side, and decided to reinstall them on the oher side, for purely cosmetic reasons. Some got damaged in the process, and I can see one that did excatly what the OP shows in the picture.
Now I still have the blue O-rings that came with the case sealing kit. Can I use those with the Dow 55 or are they going to be worse than the green ones?
The issue is the same with my SC case: the bores are not chamfered. So does this mean that the blue rings are similar to OEM (harder?) and will work better in my case?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 08-09-2013, 03:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #34 (permalink)
The blue o-rings were designed for a different sealing/washer system. They are very soft and under similar conditions will show even more damage (less chance for good sealing) than Viton o-rings. You're always taking a chance if the case holes are not properly chamfered.
Henry Schmidt
Ph: 760-728-3062
Old 08-09-2013, 03:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #35 (permalink)
Or you could just lather on some more lube, that ought to do it.
Tell it like it is or don't tell it at all.
Old 08-09-2013, 04:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #36 (permalink)
Just thought our O-ring guru would like to see what a properly cleaned engine looks like before reassembly...
Old 08-09-2013, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #37 (permalink)
Straight shooter
Lapkritis's Avatar
Metal masturbation.
Old 08-09-2013, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #38 (permalink)
Straight shooter
Lapkritis's Avatar
So the Dow 55 Silicone grease:
1) Weakens rubber tensile strength tremendously.
2) Causes rubber to swell greater than 10%; Viton actually will shrink. Common application is for temporary relief of gearbox leaks.
Keep slapping it on there though. I sure as heck wouldn't.
See for yourselves:
http://www.cibsupply.com/pdf/dc55.pdf
Old 08-09-2013, 06:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #39 (permalink)
irobertson's Avatar
Henry, would you have a nice pic of a "properly chamfered" case hole?
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 08-09-2013, 06:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #40 (permalink)
Closed Thread
