2nd valve adjust rebuild backfiring like crazy
Wondering if the backfiring is caused by incorrect valve adjustments or should I look elsewhere?
85' 911 Coupe: Rebuild complete.
Old 10-02-2013, 09:20 PM
Make that "2nd after rebuild"
Old 10-02-2013, 09:23 PM
It is more likely an air leak, or you have plug wires mixed up.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-02-2013, 11:04 PM
moneymanager's Avatar
Or you turned the crank in the wrong direction when you adjusted each cylinder. Car will run but sounds dreadful.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-03-2013, 08:52 AM
Banned
I'm curious as to what this means - how could one turn the crank in the wrong direction in such a way that if affects running later on? Are you suggesting that he may have damaged the timing chains by turning the crank counter clockwise?
Old 10-03-2013, 11:33 AM
I don't think there is anyway to adjust the valves so badly that it would cause backfiring.
Old 10-03-2013, 12:40 PM
Ronnie,
when you adjust the valves you turn the crank in a specific direction as you work from cylinder #1 onward. Go backwards and you have a disaster. The valve settings are completely wrong. Did it years ago on a Volkswagen. Jim
jhtaylor
santa barbara
Old 10-03-2013, 06:08 PM
I hear you, but it would be hard to mess it up by accident as over two-thirds of the cam surface is off the lobe. That means even if you rotate the engine with a blind spin you have a 66% chance of having the rocker face off the cam lobe, which is then in a perfect position to adjust the valves.
Old 10-03-2013, 07:25 PM
Though I feel a bit like a ya that's it "blockhead", I'm for Joy.
I crossed wires 4nad5 or 5and4 however you want to look at it.
I love this place.
Thanks for the help...
Old 10-03-2013, 08:11 PM
Shane, you may well be right but just try it then start the motor. It will run, and sound like you put quarters thru all of the spark plug holes.
jhtaylor
santa barbara
Old 10-03-2013, 08:26 PM
I love this place.
Great! Thanks for the follow up.
Old 10-03-2013, 10:12 PM
Arrow
Nope, not gonna do it, even though the odds are good, I am not willing to take that gamble.
... Even if I did do it with a blind spin, and stopped on the lobe I would be able to tell because if the valves were even close before, then I would have to back the adjuster out all the way to release the spring tension. That would be an indicator that I was going down the wrong road. I do understand how it could happen to someone who had never done a valve adjust. Good point, thanks!
Old 10-03-2013, 10:14 PM
