carrerarsr65
money no object? $$$
lets play a little bit money no object how would you build a 3.0 n.a. motor
Banned
well ... twin plug RSR MFI engine .
Try not, Do or Do not
Here's an engine we built to test a new concept where no expense was spared.
This was a 2.5 SS, Ty rods, peanut heads and custom built slide valve system. 11.5:1 compression with flat top pistons to reduce the propensity to detonate that accompanies the standard Porsche hemi head. ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Geez Henry...looking at that work of art makes my eyes flutter!
When they settled down, all I could say was ..... WOW ...thank you for brightening my day. Bob
Bob Hutson |
And then there was this engine, built on a 3.0/3.3 turbo case.
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve 1982 930 Turbo case (GT3 squirters) Shuffle pins Boat Tail Supertec SuperCrank billet 66mm full cross drilled R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal) GT3 Bearings coating by Calico Coating 996 TT oil pump Racing IWIS chains Supertec idler arms 964 steel counter shaft Supertec Head studs LN Nickie cylinders 100mm Supertec 906 cooling tin 10:1 JE FSR pistons, 60 grams lighter than conventional pistons Custom DC 80 cams Early forged rockers w/dry film pads Extreme Cylinder heads Port Flow Analyzer v3.0 EXTREME CYLINDER HEADS 50mm PMO Carbs (manifolds 41 x 50mm) Burnham Motorsport Twin plug distributor Burnham Motorsport sump cover Series 900 fan shroud Supertec Power Pulley Supertec RSR flywheel Extreme Cylinder valve springs and titanium retainers Hargett valve covers M&K RSR muffler Ceramic coated 1 3/4 German Racing headers Custom wiring harness by Supertec Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-20-2013 at 04:52 AM.. |
Great thread and thanks Henry for the engine porn for us to all drool over.
Since I am in the process of piecing together by dream engine, I wonder how much a difference some of the stuff makes other than the neat machinery, bling effect. Can you tell the difference (say with the peanut head) in terms of power? Is the balancing to the nth degree detectable by mere mortals? The hopeful part of me says yes.....but the little nasty guy on my shoulder says "don't bother". Love to hear stories from people who have experienced our rather more mundane engines that most of us have and the really wonderful mechanical artistry such as the stuff that Henry builds. BTW, my dream build parts list (at least what I have on hand now is): Brand new Carrera engine case Brand new 74.4 Turbo crankshaft Mahle 98mm Nikasil P/C's with 10.3 compression Carillo rods Turbo oil pump 964 steel intermediate shaft Big port heads (930/03), dual plugged, titanium retainers 993 Turbo studs and nuts (sorry Henry) Doherty DC35 cams with new rockers PMO ITB intakes with MFI air cleaner assembly SSI exhaust Mark Montshagen ceramic coated fan/housing All mounted to my 6 speed, in my heavily modded '89 chassis (backdate, no sunroof, removed drip rails), Dennis |
Crusty Conservative
Dennis,
Aren't the SSI's too small for that build? I love SSI's personally, but always hear that they constrict the breathing on engines like you are contemplating. I think you could get your money out of those easily & move on to a larger diameter set of headers, maybe even with heat...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I just have never found an exchanger with good heat that I liked. I always wondered why SSI didn't make a version with 1/8 inch bigger pipes, but until they do, I will live with the cut in max hp in exchange for real heat plus beauty. Advice from others seems to confirm that while the SSI's are little small but work well enough..... Dennis |
