Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by 304065 View Post
I nominate this hammer as the "Pelican Cudgel of the Year" for 2014
The preferred weapon of a true "Porsche Jedi".
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-04-2014, 10:30 AM
fred cook's Avatar
Splitting the case.......
When I split the case on my SC engine, I left 2-3 nuts on the studs but a few turns from being tight. Then I turned the engine in the stand so that the mounted side of the case was on top. That way, I had gravity helping to pull the case halves apart as I tapped on the various spots at each corner. After just a little while, the two halves separated but only about 1/4" because of the nuts left in place. Then it is just a matter of turning the engine back over and finishing the disassembly. Just another way to skin a cat!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 02-05-2014, 05:21 AM
Engine case is split!
Thanks to all the advisors on splitting my 81 sc case; this site is an unbelievable resource for newbies like me. My face is a little red as I had missed the bolt in the chain housing. I used the "tapping on the engine holding mount" technique, though i don't have a cool copper headed hammer like the one in the photo!
The inside of this motor stinks to high heaven, it suffered an oil deprivation issue, so I imagine that is the smell of burnt motor oil. I am a novice, as I said, but the internals look good. The total damage I can confirm is seized camshaft, one broken rocker, and a stripped cam chain sprocket. I guess the hard part starts now…….
Old 02-05-2014, 12:36 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The heat generated by the oil problem is your main concern.
Once you get the case stripped of all parts...clean the mating surfaces and check the crank bore for size and straightness.
I suspect you will need an align bore.
Bob
Bob Hutson
Old 02-05-2014, 06:27 PM
splitting the case
Thanks to irobertson for the idea to use a bottle jack. I tried most all of the other suggestions and couldn't get it open. I used the bottle jack to apply a little pressure then using a hard rubber hammer was able to split the case.
Old 01-25-2016, 04:34 PM
