Call 911
dkirk's Avatar
Hi Gary,
Thanks for the kind compliment on the tool. Glad to hear that the simple modification made an improvement for use on your engine. If you ever need additional spare parts, don't hesitate to contact me.
Dave Kirk
My Porsche restoreth my soul.
Old 09-18-2015, 11:01 AM
How about the video please?
Old 09-30-2015, 07:39 PM
Send a message via AIM to MrNvgtr
Hello. I'm considering the purchase of this tool for my next valve adjustment. As time is apparently against you on this video thing, how about a quick video vignette of the process for adjusting just one valve?
This being my first valve adjustment in preparing for, I've done a lot of research, albeit in a very compressed amount of time, and the method using this tool seems quite simple and it appears feedback is consistently good. My mind was originally boggled how the dial gauge methods I've read about produce such mixed results, but I think I'm beginning to understand the mechanics behind the method of measurement which differentiates this from the dial gauge methods. Basically this tool uses the accuracy of the known thread count of the valve adjuster screw, while all other methods use the rocker, which due to its inherent play and the sensitivity of the gauge, are prone to inconsistent error prone measurements. I'm sure there are experts who use these tools correctly, but we mortals have to realize our inconsistent techniques add a multiplier to the equation as well.
Anyway, I'm more of a visual / hands-on learner, so those of us like me out there would appreciate a video explaining and illustrating the mechanics of how this tool works.
Old 10-11-2015, 10:30 PM
Kartoffelkopf
Spenny_b's Avatar
Really, you'll find that once you try the first valve, it's child-play, you dont need a video. Once you buy one, the only counsel I would give, having now used the tool to check and adjust all 12 valves 3 or 4 times, is to just get comfortable with the feel of how tight a closed rocker should feel before winding it back the 0.1mm and locking...i.e., it's not TIGHT, it's just nipped...undo/redo/undo/redo 3 or 4 times and you'll soon get a consistent finger-torque feeling that's repeatable across the remaining 11.
Caveat: My experience is only with the engine on a stand, I've not yet had the "pleasure" (!) of doing this in-situ...on a Turbo lump....packed with stuff....it's going to be a real delight (I'll probably drop the engine, it'll be less frustrating than removing the tinware and contorting myself upwards for the inlet valves)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 10-13-2015, 03:39 PM
Thanks for the input. I think you're probably right. I'd just prefer as much prep beforehand to help build confidence going into unknown territory.
Old 10-13-2015, 04:55 PM
Will this tool work on a turbo motor? Are there any clearance issues on Exhaust Valve #1 and wastegate?
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 10-13-2015, 05:06 PM
Kartoffelkopf
Spenny_b's Avatar
John
Can't give you a definitive answer I'm afraid, I'm not running the stock WG (now have a pair of Tials that are well out of the way of the exh valve covers)...but when it was stock, I remember that even getting the lower 1-2-3 valve cover off with the stock WG was a wrestle. With a screamer pipe, it was far easier to just unbolt it, but this may not be the case with a stock muffler on the end of it.
Old 10-13-2015, 11:56 PM
I am running a Powerhaus header with a Tial F46 Wastegate. I have no issues removing the valve cover, but do recall having some issues getting screw driver in there to hold the lash adjuster.
Old 10-14-2015, 08:38 AM
iwhelan's Avatar
I just wanted to add to this thread that I used the tool this past weekend to do my first valve adjustment on my '87 911, and it was a piece of cake. I had never done a valve adjustment on any car before. If you just take your time, and go step by step it's fine. The valve sound great, much quieter than before. It just takes time to get the AC compressor out of the way, move the ignition wires out of the way, take off the valve covers, etc, but if you give yourself a day and don't even work fast you'll be done before dark. Great tool!
Old 03-30-2016, 05:21 AM
Kartoffelkopf
Spenny_b's Avatar
Yup, further to my posts above, I've also recently now used the tool to perform the check/adjustment in-situ. Piece of cake. Of course, tinware needs removing, but was a lot easier and quicker than I expected.
Double checking with a feeler gauge also proved to me that it was accurate and consistent; can't ask for much more than that.
Old 04-04-2016, 05:34 PM
Video?
WHERE IS THE VIDEO?!?!?!?
Old 08-25-2016, 06:04 AM
toddu's Avatar
Honestly, I don't see the need for a video. Pretty straightforward how it works.
Todd
'81 SC
Old 08-25-2016, 06:08 AM
iwhelan's Avatar
I didn't remove the tinware, so this is not essential. If you want to remove it for fun, go for it though.
Old 08-25-2016, 06:47 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey DK,
Geez, I am late to this game. I bought the tripod tool, the pins fell off so now I have a very expensive short screw driver
So I can not seem to find the tool on the parts section.
I would like to order one.
Please advise,
Jim
'85 Carrera Targa
PCA/POC
Old 08-25-2016, 07:37 AM
DRACO A5OG's Avatar
Oops, never mind, found it
1985 Porsche 911 Carrera Targa - Engine Tools - Page 2
Just ordered :-)
'85 Carrera Targa
PCA/POC
Old 08-25-2016, 07:40 AM
Call 911
dkirk's Avatar
Jim -
Thanks for your interest. Please let me know if you have any questions.
Several customers have contacted me recently, saying that they received a tool with no instructions included. I furnish written instructions with every tool provided to Pelican, so I'll have to address that.
Also, any purchasers of this tool that have problems, require modifications, need spare parts, just don't like it, need an instruction sheet, etc., please contact me at dkirk@milwpc.com and I'll respond pronto.
Thanks to all who have purchased this tool and for your kind remarks!
Dave Kirk
Old 08-25-2016, 10:33 AM
DRACO A5OG's Avatar
Master Dave,
Just will called the tool plus a huge telephone book of literature for your SST , Nice
Looking forward to using it, I can no longer trust my old hands and feel
'85 Carrera Targa
PCA/POC
Old 08-25-2016, 12:20 PM
DRACO A5OG's Avatar
LOL. Master Dave, now we know why some did not get the manual, they gave them all to me
I will go back and return it, lucky I live 5 minutes away.
'85 Carrera Targa
PCA/POC
Old 08-26-2016, 07:50 PM
83 911 Production Cab #10
JJ 911SC's Avatar
PP version: Porsche 911 Kirk Engines Valve Adjustment Procedure | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Who Will Live... Will See
Old 08-27-2016, 03:07 AM
Originally Posted by dkirk View Post
Jim -
Just received my tool yesterday from Pelican. Arrived very quickly but no instructions.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 08-27-2016, 07:16 AM
