LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Straight shooter
Lapkritis's Avatar
I would recommend holding onto those stock bearings in good condition until the engine is together and running - seems it can be a challenge to find suitable aftermarket quality.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-30-2014, 09:53 AM
I am not throwing anything away until the build is complete. Everything that I have removed has been bagged and tagged.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 06-30-2014, 11:13 AM
What is wrong with the bearings offered by our host?
Tom Feeney
1970 911 T
1973 911 T
Old 06-30-2014, 02:38 PM
Concern about quality of Glyco rod bearings
There has been a lot of recent discussion on the Forum about the quality of Glyco rod bearings. Seems to be a new development where standards have fallen off.
Look for this thread which has good photos.
Glyco rod bearing wear
How may miles had your 3.0L motor done? Amazing engines for a sports car!
And how did your crank measure up - do you have any grooves from oil seal wear?
Old 06-30-2014, 04:13 PM
Supposedly it was a 65,000 mile roll over.
I haven't done anything with the crank yet.
There are no grooves at all from the seals
Tom Feeney
1970 911 T
1973 911 T
Old 06-30-2014, 05:03 PM
Tomorrow, pressure wash and completely clean engine. Look for before and after pix.
Tom Feeney
1970 911 T
1973 911 T
Old 07-03-2014, 05:33 PM
Before pictures
Here is what it looked like prior to pressure washing
Tom Feeney
1970 911 T
1973 911 T
Old 07-04-2014, 07:54 AM
After pictures
I used an old dryer brush used to clean lint from a dryer to clean out all of the holes. It worked like a champ. I then pressure washed and scrubbed with a Scotch Bright with some dish liquid. It came out ok but I will follow up with some long Q-tips to reach those out of the way places.
Tom Feeney
1970 911 T
1973 911 T
Old 07-04-2014, 07:59 AM
Next step
So, a bit more cleaning of the block. Once I am happy with it I will install new main bearings. Since I don't own the tools needed to measure the crank and the bearings I will use plasti-gauge. Some homework is needed to see how thus is done so time for some reading.
If anyone has done this and can share their experience please chime in.
Tom Feeney
1970 911 T
1973 911 T
Old 07-04-2014, 08:05 AM
Used plastigage many times over the years. There are no tricks, really, to using it. Everything has to be completely dry and clean (no oil on crank journals), and you have to ensure that you don't turn the crank or you will smear the little plastigage rope. Make sure that there aren't any burrs or nicks on the main bearing webs or any of the machined surfaces before you assemble.
Old 07-04-2014, 10:54 AM
I have used it in the past too but not on a Porsche engine where the case is the cap. Do I have to torque the entire case down to do it or just the bolts that surround the mains?
Tom Feeney
1970 911 T
1973 911 T
Old 07-04-2014, 11:49 AM
Amstaff, good question! Perhaps someone who has done many Porsche engine builds has tried it both with and without the perimeter bolts. My sense is that you will get good readings with just the main through bolts torqued, but maybe somebody knows differently.
Old 07-04-2014, 01:53 PM
Pistons and cylinders
Well, today was piston and cylinder day. I bought walnut shell blast and used my handy dandy blasting cabinet and cleaned them. They weren't really bad so they came clean pretty quickly. Once cleaned I scrubbed them with dish liquid and a scrub brush. When I cleaned the pistons I pulled all of rings off, cleaned the ring groove, inspected the rings and reinstalled them. I still have to tear down, inspect and clean the heads and then I will empty the cabinet of the walnut and change to sand to do the hard parts.
I decided to have the rods done so they will be sent out sometime in the near future.
Next weekend, heads!
Tom Feeney
1970 911 T
1973 911 T
Old 07-13-2014, 09:09 AM
Horrido's Avatar
Sub'd
You are never too old to have a happy childhood.
Old 07-14-2014, 06:02 PM
Rods
Well, I know this is kind of slow but I pulled all of the rods and bagged them with the old bearings and the wrist pins. Now to find a shop to recondition them.
Tom Feeney
1970 911 T
1973 911 T
Old 07-24-2014, 04:00 PM
Crank
The crank is now bare of rods. The journals look good. For my own reference as the crank stands up with all of the rods pointing at me the numbers on the rods are on the right hand side.
The crank will also make it to the shop for a checkup.
I hear good things about JB Racing in Tavares. I will start there.
Tom Feeney
1970 911 T
1973 911 T
Old 07-24-2014, 04:20 PM
Gordo2's Avatar
Plastigage Experience
Ooo - I can help with that one...
Checking Connecting Rod Bearing Clearances With Plastigage
I checked the rods and mains with Plastigage
Feel free to comment on the above thread if you have any recommendations to assist the instructions/process.
Good luck,
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 07-24-2014, 07:50 PM
Cleaning and more cleaning
Well, I figured out why a rebuild at a shop is so expensive. It takes a ton of hours just to clean everything!
Today I got a few pieces cleaned up but there is still a lot to go.
Tom Feeney
1970 911 T
1973 911 T
Old 07-26-2014, 09:35 AM
Shroud repaint
The shroud got a good repaint today. I used Krylon engine paint which I have used before. It works great and sticks like glue
Tom Feeney
1970 911 T
1973 911 T
Old 07-26-2014, 09:40 AM
Nice job
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 07-26-2014, 12:18 PM
