-   -   Rookie 3.0 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/817029-rookie-3-0-rebuild.html)
Amstaff 03-12-2015 04:47 PM
Put oil in the top of the tensioners and pumped them up and down until they pumped up. I will probably do it a few more times before buttoning it up.
Amstaff 03-20-2015 03:48 PM
Rocker Arms
Put all of the rocker arms in today and got them all set. I will run through them once more just to make sure.
http://forums.pelicanparts.com/uploa...1426891694.jpg
Amstaff 03-20-2015 03:52 PM
Tensioners
Ok, so I would like to spend $1500 for pressure fed tensioners (I also would have liked to have dropped $5000 for P&C's too) but there is only so much money to do this engine. I opted to use the tensioner guards that I purchased from our host.
http://forums.pelicanparts.com/uploa...1426891922.jpg
http://forums.pelicanparts.com/uploa...1426891949.jpg
Amstaff 03-20-2015 03:54 PM
Sunday I will check the rockers one more time then put valve cover gaskets on. Then cam housing covers, Tins, etc...
Jcslocum 03-20-2015 06:23 PM
You are making excellent progress. Keep up the good work and the pictures are a big help!
michael lang 03-21-2015 12:43 AM
thank you for explaining how you got through the timing process, that has me a little confused. I'm sure that once I go through it I will realize that it isn't as intimidating as it appears.
Amstaff 03-21-2015 05:27 AM
I was really intimidated by the cam timing. Besides having to do it several times to make sure it is 100% accurate it wasn't hard at all. When I see people posting that they couldn't get it exact so they just set it at "X" I though "well, as long as I am close " but after doing it I realized that if you don't get it 100% correct you just didn't spend enough time on it to get it right.
Amstaff 03-22-2015 04:51 PM
Finishing up
Ok, here it is buttoned up and ready to go.
http://forums.pelicanparts.com/uploa...1427068244.jpg
http://forums.pelicanparts.com/uploa...1427068273.jpg
Amstaff 03-22-2015 04:52 PM
http://forums.pelicanparts.com/uploa...1427068322.jpg
http://forums.pelicanparts.com/uploa...1427068353.jpg
Amstaff 03-22-2015 04:53 PM
Just a few tidy up things to finish and then time to install it
Amstaff 03-22-2015 05:00 PM
Any questions or comments?
Did I miss anything?
N-m 03-22-2015 06:43 PM
Is that a bent cooling fin behind the distributor cap?
kgieg 03-22-2015 08:22 PM
Looks great ! :) Can't wait till mine is at that stage.
Amstaff 03-25-2015 06:36 AM
Broken fin
Yep, it had one broken fin. Good eye!
Dpmulvan 03-26-2015 04:26 PM
Nice job!!
Targa4now 03-30-2015 06:26 PM
Nice work and thanks for taking the time to share your experience!
Speed Buggy 04-05-2015 05:52 PM
I was very nervous about the cam timing as well and even let it slow me down while I read all over this board. Did you have trouble tightening the exhaust while the engine is still on the stand?
Amstaff 04-05-2015 06:04 PM
Haven't installed exhaust yet. Headers are on the way and engine will be installed this weekend. Look for updates this weekend.
Amstaff 04-10-2015 05:36 PM
Motor install
Getting ready to install it!
http://forums.pelicanparts.com/uploa...1428712562.jpg
Amstaff 04-10-2015 05:38 PM
Motor install
http://forums.pelicanparts.com/uploa...1428712683.jpg
Amstaff 04-10-2015 05:39 PM
Motor install
http://forums.pelicanparts.com/uploa...1428712741.jpg
Just need to tidy up loose ends
http://forums.pelicanparts.com/uploa...1428712795.jpg
Amstaff 04-10-2015 05:41 PM
Just need to wire the distributor, install fuel lines and plug in the loose wires. Headers won't be here until next week so I am trying to decide if I should put the old ones on and run them for the break in period.
michael lang 04-11-2015 12:24 AM
just out of curiosity, why did you not finish the reassembly before putting it back in your car? I would think it would be easier for access to everything vs. having reach in and feel your through everything and crawling around on your garage floor.
Amstaff 04-11-2015 05:27 AM
What do you mean by finishing the assembly? What else should have I put on it?
The reason the alternator wasn't on is it needs to be wired, carbs because I have always had clearance issues with the carbs on because I usually can't get the car high enough and the coil can't go on until the alternator is on.
Otherwise the motor was pretty much together. If you think I should have at least had the carbs on you are 100% correct, if I thought the car was high enough it certainly would have made it easier. I just remember the last time that I didn't have the car high enough and had to pull them off to get the motor under the car.
Amstaff 04-11-2015 05:28 AM
Funny how it took 3 hours to remove the engine and 7 hours to put it back in.
mreid 04-11-2015 05:45 AM
Don't you love how that works! Seems the time space continuum becomes warped on reentry.
Great job all around!
Amstaff 04-11-2015 06:21 AM
Gravity is your friend when you pull the engine and your enemy when you install it!
michael lang 04-11-2015 06:41 AM
You just answered my question. I figured it might be as much as a clearance issue but wasn't 100% certain. You could have always gone with something like this
http://images.tapatalk-cdn.com/15/04...b1889c9faa.jpg
Those blocks combined with my jack stands gave me this this height at the rear bumper
http://images.tapatalk-cdn.com/15/04...cabd5664c9.jpg
I haven't gotten to re installation yet, I can't wait for that adventure
toddu 04-11-2015 06:45 AM
Midrise lift and a hydraulic table = 30 minute job. :-)
Todd
Amstaff 04-17-2015 04:18 PM
Headers are here!
Now if I can just find the Delo SAE 30 oil I will be ready to start it up!
Amstaff 04-18-2015 05:11 PM
Filled it with oil tonight. I was really expecting a flood of oil to come pouring out of the bottom but not a drop!
Tomorrow night exhaust and start up.
mreid 04-18-2015 06:45 PM
The three milestones of engine rebuilding:
1. Installation - exciting
2. First Start - nerve racking
3. First Drive - exhilarating
Amstaff 04-19-2015 04:47 AM
I am super nervous about the start up.
billybek 04-19-2015 05:54 AM
The squeeze at the back door is super tight when firing a new overhaul for the first time...
Good luck and post a video (of the engine, not the back door)!
mreid 04-19-2015 07:24 AM
Completely understandable! Particularly considering you have to run it at a higher rpm for 20 minutes to break in the cam/rockers.
The good news is that you will have super hearing the first few times you drive it!
Amstaff 04-19-2015 02:38 PM
Fire it up!
Well, fired it up tonight.
Cranked right up without hesitation and ran smoothly for its 20 minute break in period.
Not a single drop of oil and no funny noises!
Drained the oil and hardly a spec of anything in the oil!
https://youtu.be/rOlBurkiRMg
Amstaff 04-19-2015 02:42 PM
Now the big question.
I ran Delo SAE 30 for the break in period.
Do I change it o 20/50 now?
911 tweaks 04-19-2015 03:58 PM
YES...especially simce u have run the break in which I would of used the Joe Gibbs Break in Oil but too late for that now...so going fwd use joe gibbs driven driven 15/50 = their DT50 as it has the hi zinc level...I use ONLY JB oils for ALL of my clients and my cars...period... not a spokesperson but NO other oil has this correct additive pkg on the market...recommended by LN Engr & jake rabey & others...hope your rebuild is what u hoped for...bob )))
Amstaff 04-19-2015 04:16 PM
Is that synthetic oil?
