It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Looks like an engine again. Woohoo.
My son helping with the assembly of cam towers.
Days work. Ordered new idler sprockets so on to other activities, cleaning shroud, cleaning up trans, replacing the exhaust studs.
My wife torquing the cylinders / cam towers
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 06-25-2014, 03:54 PM
Air Medal or two
afterburn 549's Avatar
Please cover your ports
Besides that it looks good !
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-25-2014, 04:04 PM
It's a trap...
Yep, good call. Thanks.
Old 06-25-2014, 06:56 PM
Hell Belcho
Nostril Cheese's Avatar
I might also suggest keeping the cam chains somewhat taught against the intermediate shaft gears. I've had a chain slip off before and it was a pain to get it back on.
Old 06-25-2014, 07:07 PM
Congrats, I bet you can't wait to fire it up.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 06-25-2014, 07:31 PM
Air Medal or two
Your looking Great! You should be up and running in a week or so!
What engine is it and how is it spec. out ?
Old 06-26-2014, 12:50 AM
911 2.2 T targa
Where are the oil return tubes???
Old 06-26-2014, 04:54 AM
tharbert's Avatar
I've never worked with the engine on my belly like this. Does it make it any easier?
Hope I'm not too far behind you. Looks great!
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 06-26-2014, 05:32 AM
It's a trap...
Heinz911 - She was torquing to take the solder measurement, not final assembly.
Afterburn549 - Motor is a stock 3.0L. I had a chain tensioner fail and shaved some aluminum off of the chain box internal oil (?) shelf while breaking a number of idler sprocket teeth. I sent the cooler to pacific oil cooler. New engine harness from Timmy2 on this board. That's it.
Tharbert...does your pic come out sideways on you screen? Haha
I am excited to get back on the road. Will do on the chain tension. Thank you all.
Old 06-26-2014, 06:40 AM
porschetub's Avatar
My son did head torques on our offroader @ age 13 and my wife and I did motor/gearbox changes on her 57 oval bug before the kids came along,very cool,great to see,thanks for sharing.
Just about to get into my 2.2t and the pics help , doing a good check over in prep for going into my 914,not as far as you have gone but a tidy of of known bad spots,the triangle,chain ramps,rear seal,intermediate shaft cover and all the "while you are in there stuff",cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-06-2014, 08:35 PM
It's a trap...
I love when the stars align and I actually get help. Tara replaced one side of the ball joints on our '86 Jag while I did the other side. She's a gear head. Pretty cool! Good luck with the refresh. Cheers, Mike.
Old 07-07-2014, 07:43 AM
