Rarly8 Headers Change Silikon hoses to Aluflex
The Silikon hoses with the heat insulation tape was not mine.
I have made an aluminum adapter for the Aluflex. but first comes the 3ldz out:) http://forums.pelicanparts.com/uploa...1421508581.jpg http://forums.pelicanparts.com/uploa...1421508594.jpg |
Adapter for Heater Box (new all in Black)
New Paint in black with Adapter
http://forums.pelicanparts.com/uploa...1422098407.jpg http://forums.pelicanparts.com/uploa...1422098441.jpg New K27/29:) http://forums.pelicanparts.com/uploa...1422098483.jpg http://forums.pelicanparts.com/uploa...1422098531.jpg http://forums.pelicanparts.com/uploa...1422098567.jpg |
Even if I prefer raw, black looks beautiful. Nice work!
New Aluflex Tubes
I like the Aluflex vs Silikon Tubes (with heat Tape)
http://forums.pelicanparts.com/uploa...1422129097.jpg http://forums.pelicanparts.com/uploa...1422129207.jpg http://forums.pelicanparts.com/uploa...1422129231.jpg |
Modification Air Filter Box
I still had problems with the fitting between the TK intercooler and the Air Filter Box.
Again i cut some Piece out and fix it together. http://forums.pelicanparts.com/uploa...1422129712.jpg http://forums.pelicanparts.com/uploa...1422129722.jpg http://forums.pelicanparts.com/uploa...1422129732.jpg http://forums.pelicanparts.com/uploa...1422129745.jpg http://forums.pelicanparts.com/uploa...1422129760.jpg http://forums.pelicanparts.com/uploa...1422129770.jpg |
First Drive with the New K27/29
The First Drive with the "new K27/29" was good:D, no Problems.
The difference of the different exhaust turbine is very noticeable. I have the Data from Zeitronics as the compressor nut coming loose (3.Gear) http://forums.pelicanparts.com/uploa...1422301079.jpg |
Current AFR Results
My current AFR results looks not to bad.
http://forums.pelicanparts.com/uploa...1422301596.jpg http://forums.pelicanparts.com/uploa...1422301621.jpg I must do test runs at maximum speed and full boost to see this afr situation. First i recheck all pressure from the CIS and make a flow testing from the injektors. |
Do you have a design or a build sheet for your engine/tranny rest? I'd love to make something similar for when I need to drop the tranny and motor.
~Andy Quote:
AFR of 14.1 - 14.2? Too lean. That is with no boost and low rpm but no room for error there.
I'm sorry I do not have a plan of the design or a build sheet. My Friend has it continuously constructed by hes engine build. The base is a motorcycle hydraulic ramp. Thomas |
In the second and third diagram you must take the values from the vertikal line.. for example: Idle 4531 / Boost 099 Bar / AFR 12.4 |
Got it, looks good. So over about how much time does the 3rd graph cover? You've convinced me to get a Zeitronix for my build. It's cheap compared to dyno time for tuning.
black pipes
I agree... the black pipe work looks ace :-) |
Yes i think the Zeitronics is a god solution (i have the little Blackbox) it helps, but a dyno is a must for me in the final. |
Subscribed
Having a similar problem with my k27HFS. I will look into the same methods of testing as well. I do not have a turbo to swap out though. Thank you for such a detailed build. Nice work.
Thank you for your kind words! |
CIS Testing
CIS Test:
System pressure was too low: http://forums.pelicanparts.com/uploa...1424534693.jpg I have ordered a new system pressure regulator to fix the Problem |
Installing Fuel Pressure Regulator and Damper
I have also ordered the Fuel Pressure Diaphragm Damper (was installed in the 930/66 S)
New Parts: http://forums.pelicanparts.com/uploa...1424535898.jpg http://forums.pelicanparts.com/uploa...1424535921.jpg http://forums.pelicanparts.com/uploa...1424535948.jpg http://forums.pelicanparts.com/uploa...1424535964.jpg |
| All times are GMT -8. The time now is 08:28 AM. |
