Installing Elbow Hose and TK Adapter LLK
Installing Elbow Hose and TK Adapter LLK:
http://forums.pelicanparts.com/uploa...1409071311.jpg Installing 4-Speed Transmission: http://forums.pelicanparts.com/uploa...1409071359.jpg http://forums.pelicanparts.com/uploa...1409071374.jpg Change OEM Starter to High Torque Starter: http://forums.pelicanparts.com/uploa...1409071451.jpg http://forums.pelicanparts.com/uploa...1409071467.jpg http://forums.pelicanparts.com/uploa...1409071478.jpg |
Awesome thread. Beautiful work! |
Assembling K27/29 Hybrid from Rarly8
Installing Rarly8 Headers and Turbocharger
http://forums.pelicanparts.com/uploa...1409134224.jpg
http://forums.pelicanparts.com/uploa...1409134238.jpg http://forums.pelicanparts.com/uploa...1409134272.jpg http://forums.pelicanparts.com/uploa...1409134295.jpg http://forums.pelicanparts.com/uploa...1409134307.jpg http://forums.pelicanparts.com/uploa...1409134321.jpg |
Installing Tial Wastegate F46 Narrow Version
Zeitronics ZT-II O2-Sensor
Installing Heater Hoses / Muffler Bracket
LLK from TK Preperation for Installation
Installing Boost Control
So i have 2 Settings 0.4 and 1.0 Bar of Boost.
The rear Wiper was removed and now i have the possibility to take the Rear-Wiper Switch to switch the valve.... http://forums.pelicanparts.com/uploa...1409154581.jpg http://forums.pelicanparts.com/uploa...1409154603.jpg http://forums.pelicanparts.com/uploa...1409154615.jpg |
Installation / Problem LLK
First i must say the Parts look good and the Customer Service from Chris is nice!
The Intercooler-Kit had 3 errors: #1 conflict with the air filter box #2 connection to supplementary air slide wrong #3 Connection to the turbocharger intercooler welded wrong (can`t close my tailgate) I have changed the air filter box and cut the connection for the auxiliary-air device #3 make my Welder right. Chris send me the reimbursement for that, Thanks Again! http://forums.pelicanparts.com/uploa...1409156905.jpg http://forums.pelicanparts.com/uploa...1409156923.jpg http://forums.pelicanparts.com/uploa...1409156940.jpg http://forums.pelicanparts.com/uploa...1409156959.jpg http://forums.pelicanparts.com/uploa...1409156977.jpg http://forums.pelicanparts.com/uploa...1409157008.jpg http://forums.pelicanparts.com/uploa...1409157033.jpg http://forums.pelicanparts.com/uploa...1409157049.jpg http://forums.pelicanparts.com/uploa...1409157067.jpg http://forums.pelicanparts.com/uploa...1409157095.jpg |
I have to admit, the engine stand scared me a littlehttp://forums.pelicanparts.com/suppo.../flylicker.gif
Glad it is in its proper place with no mishaps. Great work. |
No soft or plastic jaws for the bench vise? ts ts ts
http://forums.pelicanparts.com/uploa...1409173800.jpg But anyway, nice threadSmileWavy |
More stable than it looks
but better for engine and vehicle to use my unstable look stand as a normal jack:D |
Installing Oil Trip Tank from GSF / Final Installation Exhaust System
Oil Trip Tank, Adapter and Oil Line from GSF:
http://forums.pelicanparts.com/uploa...1409504087.jpg http://forums.pelicanparts.com/uploa...1409504117.jpg http://forums.pelicanparts.com/uploa...1409504141.jpg http://forums.pelicanparts.com/uploa...1409504169.jpg Muffler 76mm Diameter: http://forums.pelicanparts.com/uploa...1409504220.jpg http://forums.pelicanparts.com/uploa...1409504262.jpg |
Exhaust Wrap
Zeitronics ZT-II Installation
Zeitronics ZT-II (under Driver Seat)
- Zeitronix LCD Display - Black Box Data Logger - Wideband Air Fuel Ratio Meter - Boost Sensor - RPM Signal logging - Knock Sensor http://forums.pelicanparts.com/uploa...1409505243.jpg http://forums.pelicanparts.com/uploa...1409505253.jpg http://forums.pelicanparts.com/uploa...1409505268.jpg http://forums.pelicanparts.com/uploa...1409505281.jpg http://forums.pelicanparts.com/uploa...1409505295.jpg http://forums.pelicanparts.com/uploa...1409505309.jpg |
To avoid of installed(settled) this thermal protection there is another solution than I envisage seriously, that to make a ceramic treatment(processing) on the collector of escape by the company Zircotec, it is not given but do not apparently very effective. I have just joined but I am your restoration(catering) for a long time as that Spenny-b, bravo, your work is great(tremendous)! ;) |
| All times are GMT -8. The time now is 04:20 PM. |
