greasemonkey's Avatar
Cylinder ID and use. Help please.
Hi guys,
I have a '79 SC and have a badly scored bore in one cylinder - Alusil cylinders
I have found a replacement Cylinder but the markings are different;
The original is 885/1B +
The replacement is 885+ A
Will I be ok to put this one in? What is the difference?
(Photos below)
Thanks in advance.
Greasemonkey.
1974 911s (Backdated to RS Clone), 2006 Cayman S, 1963 MGB
Old 08-11-2014, 07:35 AM
I don't know what the different markings mean. All you care about is the fit of the piston and the height of the cylinder. You can measure the fit by using a feeler blade between the piston skirt and the cylinder wall. Compare with your old cylinder. Should not be more than .004 inches clearance. The height is important so as to not bind the camshaft when installed.
-Andy
Old 08-11-2014, 08:17 AM
Thats a casting number
What you want to match is the number stamped into the cylinder base 0, 1, 2 for size
and the deck height inside a triangle, either 5 or 6
Both numbers are measured and stamped onto the top of the cylinder base, around 90 degrees from where you took the picture of the casting.
Bruce
Old 08-11-2014, 08:26 AM
Hi Bruce,
I have found some of the numbers;
The original cylinder has a 1 stamped onto it,
The new(used) one has a 0 stamped on it.
Both were where you said.
I can't see any further numbers.
Can a 0 be machined to be a 1 ?
Thanks in advance.
Greasemonkey.
Old 08-24-2014, 01:40 PM
DSPTurtle's Avatar
Does your piston have a one or a zero stamped on the face? It matches with the cylinder. Has to do with tolerances between the skirt and the cylinder.
Old 08-24-2014, 02:41 PM
Here is where to look for the markings.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-25-2014, 05:14 AM
