It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
New alternator fan housing, no timing mark??
Got a new fan housing from our host. Small crack, looks like it was dropped, won't affect operation....but - the new housing does not have a timing mark on it. What is the remedy for that? Do I put number one at TDC and then mark it?
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 11-01-2014, 08:44 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The one I bought did have the mark but I verified it anyway and found it was out a bit. So yes, find TDC, (both valves closed) a dial gauge is best but not mandatory and mark the housing. I used a 3 point file to cut a groove. At least you will have 100% confidence in the reference mark.
1986 Targa Guards Red
2021 MT09 SP
Old 11-01-2014, 09:01 AM
It's a trap...
Thank you.
Old 11-01-2014, 09:03 AM
Note that the mark on the fan housing lines up with the seam of the case, so checking the top of the piston travel, the real way of determining TDC, is unnecessary.
The Cap'n
Old 11-01-2014, 09:39 AM
It's a trap...
Oh yea. Forgot about that. That's where the old razor blade trick comes in. Thanks.
Old 11-01-2014, 09:58 AM
The fan housing TDC marks I've seen don't line up with the case seam.
Now you can carefully put a TDC mark in it that does line up with the case seam if you want.
A center punch would work good to make the mark and a little white paint in the punch mark would make it easier top see.
Old 11-01-2014, 04:04 PM
It's a trap...
That's a great idea. I have some metal markers that will work great for that. Thank you. Almost done with the assembly. Woot woot.
Old 11-01-2014, 04:21 PM
If that's the case, why does the manual show checking the cam timing before the alternator fan ring is installed?
The Cap'n
Old 11-06-2014, 12:18 PM
Always use the case seam when setting cam timing. The fan housing mark is not accurate. If the TDC slot in your crank pulley is accurate it should be good.
Marking it with a sharpie pen and then going over the case seam with a machinist scribe makes it easier to see.
Old 11-06-2014, 01:05 PM
