911 and 915 Differential same?
Hi there,
just being far away from my workshop and stock a question strikes my mind which i hope you can answer: 901 gearboxes and 911('70-'72) had different differentials. How about 911 and 915? Do the diffs have the same outer dimensions, i.e. are they interchangeable? Thanks and greets, Robert |
Max Sluiter
As far as I know the 911 and 915 differentials are interchangable.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
i agree ... they did have different style splines early (coarse) vs late (fine) but can be interchanged if they have the appropriate shafts.
gearhead
Yes and no. '72-74 915 with 7:31 cwp uses the same differential as a mag case 901(69 only),911(7071)&914 gearbox.
When they went 8:31 the ring gear offset changed. The course spline middie differential is not a direct fit. |
Great info.
so i would need an early 915 (i assume the non upgraded one with the uneasy input shaft seal exchange) to be able to interchange said 911 diff? Thanks and greets, Robert |
