911 and 915 Differential same?
Hi there,
just being far away from my workshop and stock a question strikes my mind which i hope you can answer:
901 gearboxes and 911('70-'72) had different differentials.
How about 911 and 915? Do the diffs have the same outer dimensions, i.e. are they interchangeable?
Thanks and greets,
Robert
Old 02-03-2015, 04:35 PM
Max Sluiter
Flieger's Avatar
As far as I know the 911 and 915 differentials are interchangable.
Old 02-03-2015, 06:25 PM
i agree ... they did have different style splines early (coarse) vs late (fine) but can be interchanged if they have the appropriate shafts.
Old 02-03-2015, 07:57 PM
gearhead
Yes and no. '72-74 915 with 7:31 cwp uses the same differential as a mag case 901(69 only),911(7071)&914 gearbox.
When they went 8:31 the ring gear offset changed. The course spline middie differential is not a direct fit.
Old 02-04-2015, 07:08 AM
Great info.
so i would need an early 915 (i assume the non upgraded one with the uneasy input shaft seal exchange) to be able to interchange said 911 diff?
Thanks and greets,
Robert
Old 02-04-2015, 05:52 PM
