Converting case and oil system to JIC Fittings
So I have seen a few builds with JIC (AN) fittings for the oil system and considering I am fitting my 3.2 to a VW van I will need to do this as the standard fittings wont work. How hard is it to convert the case, oil cooler and oil tank?
Anyone?
abides.
Try Pegasus for the adapter fittings.
Graham 1984 Carrera Targa |
You need these. Easy as long as you have clearance for the longer fitting.
https://www.pegasusautoracing.com/group.asp?GroupID=PLUMADAP30MM |
