				Camshaft options for 3.0 w/carbs?
			Would like some suggestions on a hotter cam for weekend/autox SC.
				Single plug , 9.5 JE pistons (with valve reliefs) and Webers. I have 964 cams in there now but perhaps theres other options since I ditched the CIS. Thanks
	-Vinny 1983 911SC  |
			Webcam 464/465
			Quite a few options out there with those pistons.
			What sort of RPM do you want to rev it to? You want a peaky motor or one with a wide power band? Midrange torque or top end HP? Cheers
	Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3  |
				Give John A Call
			I have a similar setup and called John Dougherty to get a recommendation. Dougherty Racing Cams
			I told John my engine specs and use (street) and that I wanted to increase my lower RPM torque - he recommended his GT2-102 cams. I'm satisfied (I've spun the wheels accelerating in a straight line grabbing 2nd gear...). Equally important, consider what you want to do with your ignition - if you haven't had the advance adjusted for carbs, do that first. I used the Electromotive Xdi and have found major performance differences in how I adjust my initial timing. Here's some info on my engine and carb tuning: Gordo's PMO Carb Tuning Good luck, Gordo
	Don "Gordo" Gordon '83 911SC Targa  |
			Been a bit of time since I posted -Thanks for the responses
 Car is used mainly for autocross with some street driving so I would appreciate a wider power band and midrange torque ,car has stock valve train. not looking for a peaky engine. Ignition is already sorted with JBracing (single plug) mechanical advance distributor and MSD It is my understanding that John D no longer answers his phone or something but maybe that's changed? He did do my current 964 cams but that was some years ago. Appreciate suggestions thanks
			-Vinny 1983 911SC Last edited by Vin-barrett; 04-09-2015 at 09:23 AM..  |
			 Try not, Do or Do not
 The engine is fairly low compression so I would run something like a GE / DC40 (Mod "S") or even a slightly more aggressive GE/ DC60. John @ DC cams is my "go to guy" for cam grinder but Elgin or Web can also grind these specs.
	Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net  |
			 Schleprock
			Just last week I sent John a set of stock SC/Carrera cams for a regrind.  Answered my email same day.  He's still around and a good guy.   Just busy.
	Kevin L '86 Carrera "Larry"  |
			 Wer bremst verliert
			Ive always had good experiences with John, over 10 years now and 4 builds.
	2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy  |
