frest engine where can this leak come from?
Hi guys
just installed newly rebuilt engine with writewood racing gaskets
I have a leak by one of the nuts of the oil cooler not the part on the bottom where in it rounded?
can this come from the seal?
bolts are tight
thanks
for your help
Erick
Old 05-02-2015, 04:54 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Picture is too low quality to tell.
Can you help with a larger one?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-02-2015, 05:10 PM
Thanks Henry
here is a better picture I hope ,that's all I have
it the facing the back of the car
Old 05-02-2015, 06:30 PM
Try again.......
Originally Posted by ertech View Post
Thanks Henry
Can't see the picture. Too small for the naked eye. Try again and make it visible. Preview post before submitting. Good luck.
Tony
Old 05-02-2015, 07:13 PM
sorry here it is at the nut not the round part
thanks
Old 05-02-2015, 07:31 PM
I suppose that possibly from one of the upper seals. Did you have the cooler cleaned/pressure tested prior to start-up? I had mine fail on one of the fins close to the base of the cooler - initially thought it was a seal.
Old 05-02-2015, 08:08 PM
Yes I have it cleaned and pressure tested it was done by a company in California that does ultrasonic cleaning
Old 05-03-2015, 04:07 AM
non-whiner
mreid's Avatar
That looks like an oil cooler seal leak. However, take a fresh, white paper towel and with the engine cool reach around the intake and dab the towel all around the breather, oil temp/pressure sender area (triangle of death) and then inspect the towel. Any fresh oil on the towel may indicate this is your problem and it in running down the front of the engine by the cooler (typically how the TOD leaks show up).
"Too much is just enough."
Old 05-03-2015, 05:20 AM
YES YES YES SO HAPPY
Was the oil switch for some reason was not tight enough
Stay tuned more leaks to solve
Old 05-03-2015, 11:14 AM
Functionista
manbridge 74's Avatar
What's up with all the epoxy to left of cooler in pic?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-03-2015, 11:38 AM
On late 80's block There is a place where époxy is needed There is some sort of tube that goes through the casing
Old 05-03-2015, 12:06 PM
And it's on the inside area too under the cooler opposite where the JB weld is in the picture
Bruce
Old 05-03-2015, 02:49 PM
