frest engine where can this leak come from?
Hi guys
just installed newly rebuilt engine with writewood racing gaskets I have a leak by one of the nuts of the oil cooler not the part on the bottom where in it rounded? can this come from the seal? bolts are tight thanks for your help Erick
Try not, Do or Do not
Picture is too low quality to tell.
Can you help with a larger one?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry
here is a better picture I hope ,that's all I have leak by one of the nuts of the oil cooler not the part on the bottom where in it rounded? it the facing the back of the car Thanks |
Try again.......
Can't see the picture. Too small for the naked eye. Try again and make it visible. Preview post before submitting. Good luck. Tony |
sorry here it is at the nut not the round part
thanks
I suppose that possibly from one of the upper seals. Did you have the cooler cleaned/pressure tested prior to start-up? I had mine fail on one of the fins close to the base of the cooler - initially thought it was a seal.
Yes I have it cleaned and pressure tested it was done by a company in California that does ultrasonic cleaning
non-whiner
That looks like an oil cooler seal leak. However, take a fresh, white paper towel and with the engine cool reach around the intake and dab the towel all around the breather, oil temp/pressure sender area (triangle of death) and then inspect the towel. Any fresh oil on the towel may indicate this is your problem and it in running down the front of the engine by the cooler (typically how the TOD leaks show up).
"Too much is just enough." |
YES YES YES SO HAPPY
Was the oil switch for some reason was not tight enough Stay tuned more leaks to solve Thanks |
Functionista
What's up with all the epoxy to left of cooler in pic?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
On late 80's block There is a place where époxy is needed There is some sort of tube that goes through the casing
And it's on the inside area too under the cooler opposite where the JB weld is in the picture
Bruce |
