Trick question
Hello to all honorable forum.
i have a trick question ......my case is *6403090* and i have the craziest idea can i fit 107 mm liners and turbo piston from 993? will it fit? do i need to change the heads as well?will it work with 930 single turbo headers? please say and write all you think of give me all of your knowledge THX |
Cylinders..........
I would give the guys at LN Engineering a call. They can tell you what can be made to fit and what can't. I know that they make slip fit 100mm cylinders for the 3.0 and 3.2 liter blocks. I think that everything from 102mm and up requires machining the spigots in the block. Good luck building your monster motor!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
6403090 would be a 914-6 case. So, unless you have a typo, I'm going to say no
chance.
Mark S. '70 914-6 |
If a 914-6 case (basically same as the T), not a chance. 93mm is as wide as you can go. The 3.0 cases have a wider stud spacing, which allows the spigot to be wider, which allows wider cylinders.
