Case imperfection - leave alone or JB Weld?
Just got my case and crank back from the machine shop, I noticed this little imperfection in the case below the thermostat housing. Should I put a little JB Weld over the area or just leave it be?
![]() Thanks!
Gary R. |
I seal it with epoxy. Some of the early 3.0 liter cases leaked from this area.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thank you Aaron, i figured just closing it up would be good to prevent any further chips from coming off it too. Thanks.
Gary R. |
Fleabit peanut monkey
I have a dollop of grey epoxy on the outside in the same place on my 3.0. I never busted the case open, just a top end 15 years ago so I don't know what it looks like on the inside.
I have seen other threads where folks ask about an epoxy seal "plug" on the outside. If your garage is heated, use the regular JB Weld (you knew that) and keep it warm all night to give it a good cure. End of this week is supposed to be warmer.
1981 911SC Targa |
I did all the outside areas indicated in the rebuild manual plus filled in the webbing per the Porsche Tech Bulletin..
Gary R. |
GaryR, Can you please describe the "filled the webbing per the Porsche Tech Bulletin.." I can't seem to find the details on it. Thanks David
1970 914-6 GT Track Car 1974 IROC Track Car 1987 911 Targa 3.2 2008 BMW X5 |
![]() ![]() That is in a different area than where my internal issue was of course, but both are thin casting material over steel inserts.
Gary R. Last edited by GaryR; 03-19-2014 at 07:46 AM.. |
Thank you.
Wer bremst verliert
Woah, a Porsche Technical article recommending use of RTV...that'll blow some minds....
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
The general consensus is to fill the area with JB Weld now, but I agree, RTV doesn't seem like a great idea...
Gary R. |
As long as the exterior area indicated in the Tech bulletin is sealed, the interior will not create any leakage. My only concern would be if sealed internally, if that came loose it could damage the engine.
Ed 1973.5 T |
Does this issue apply to only the early 3.0L Al cases? I am starting a top-end rebuild on an 2.4L Mg case, and wanted to know if I should seal this area as well.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Schleprock
It applies to pretty much all air cooled engine cases because they all have the same "J" pipe that runs up the side of the case to the large bore on top of the case
Kevin L '86 Carrera "Larry" |
