Try not, Do or Do not
Henry Schmidt's Avatar
A special find in a 73"S"
When this engine was removed from it's chassis, a 1973 911 S (with Bromos race history) we were told it was a 2.7 RS. Imagine our surprise when we discovered that the engine was actually a 3.0 RS. A single plug 3.0 MFI engine built on a sand cast RSR 3.0 engine case. In 30 years this is the only one I've ever seen.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-27-2015, 07:52 AM
Over the next few weeks I'll share the build we did on this very rare engine.
Before
After
Henry Schmidt
Ph: 760-728-3062
Old 05-27-2015, 08:07 AM
91133's Avatar
Wow! That would be one time 'non-matching numbers' actually added value!
Look forward to the story.
Old 05-27-2015, 04:25 PM
Henry ... I saw pics of the headers in another post. where where they source or were they a in house custom job?
Old 05-27-2015, 04:55 PM
Skunk works
JV911SYDNEY's Avatar
Fwooor
That should come with a NSFW warning
964 RS-4
Old 05-27-2015, 06:13 PM
gearhead
So cool.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-27-2015, 08:50 PM
I would rather be driving
jpnovak's Avatar
Very Cool.
Are the case dimensions the same as the early sand cast case? I realize head stud and spigot are likely larger to accommodate the (presumably) 95mm P/C set.
Old 05-28-2015, 06:46 PM
al lkosmal's Avatar
wow, Nice find Henry.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-28-2015, 10:49 PM
Originally Posted by jpnovak View Post
Very Cool.
This very special case has the same external dimensions as all 911 cases from 64 to 89.
The unique characteristics that are different than the early 2.0 sand cast case is stud spacing half way between between 2.0-2.7 and 3.0-3.3.
Very rare. Special heads as well.
The other difference is the 5 studs for mounting chain boxes vs 3 studs and 2 pins.
The intermediate shaft has thrust bearings similar to what was common on later cases.
There are also a considerable number of reinforcements in this casting including a larger base for the cylinder mounting.
Henry Schmidt
Ph: 760-728-3062
Old 05-29-2015, 09:09 AM
Henry Schmidt
Ph: 760-728-3062
Old 05-29-2015, 09:18 AM
Henry Schmidt
Ph: 760-728-3062
Old 05-29-2015, 09:24 AM
shbop's Avatar
signing-up.
Jon
Old 05-31-2015, 04:16 AM
fred cook's Avatar
3.0 engine.......
Very interesting and a real "looker"! Are those Mahle pistons? If so, do you know the compression ratio? Also, what level of horsepower do you expect this engine to make? The pistons look very similar to the Mahle pistons that I used in my 3.3SS build. My set were 10.1:1 compression.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-31-2015, 04:26 AM
Henry Schmidt
Ph: 760-728-3062
Old 06-01-2015, 09:42 AM
Farrell's Avatar
very neat!
Old 06-01-2015, 02:04 PM
I cant believe I almost missed this.
1972 911T/S MFI Survivor
Old 06-01-2015, 10:01 PM
356RS's Avatar
Very rare engine. What a surprise.
Mark Jung
Bend, OR
MFI Werks.com
Old 06-02-2015, 09:33 AM
As we progress, we will post a pictures of the custom injection we built for this project but until then here's the pump you built for this project.
Some Supertec, some Burnham Performance and some MFI Werks magic all came together to produce a very special pump.
Burnham Performance
1071 Avenida Acaso ste.D
Camarillo, Ca. 93012
805-240-6931
rennwerks@hotmail.com
MFI Werks
10227 N.W. Swallow St.
Seal Rock, OR. 97376
Mark Jung
541-563-3702
info@mfiwerks.com
Henry Schmidt
Ph: 760-728-3062
Old 06-02-2015, 11:51 AM
BURN-BROS's Avatar
Very Cool Motor !
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 06-02-2015, 12:57 PM
Brumos called-they want their engine back.
Old 06-02-2015, 01:38 PM
