Rebuilt a set of the early 930 tensioners and installed them. I want to run the safety collar's but to many new chain related parts replaced that I can't fit the collar yet.
![]() Rocker arms installed, valves adjusted and valve covers on. ![]() ![]()
Mark Jung Bend, OR MFI Werks.com |
Looks amazing. Keeping a keen eye on this thread as I want to do some similar mods to our 3.0Carrera motor.
Childhood dream car: Porsche 959 |
Very nice Mark.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al. Working on the fitting of Damon Josz (Series 900) amber shroud pieces. Had to cut and shape the intake openings along with the MFI injector slots. Rivet on the oil cooler metal air flow piece. Lots of little adjustments but it fits very nice.
TB's fit good.
Have to come up with some kind of air filter system for my High Butterflies. Might as well use the 2.4 plastic system I have and modify it to fit on the HB's. I have a set of aluminum RSR stacks for the HB's so I cut them off 3/4's the way up, removed 1 1/4" of the stack, inserted the top section of the 2.4 stack that I cut off, opened up the stack holes to fit the HB stack top section O.D. and had them welded back up. Now that top section of the 2.4 stacks are part of the HB's.
![]() ![]() ![]() Modified the plastic air cleaner housing to fit over the HB stack top openings and then clipped the thing together. ![]() ![]() ![]()
ok....now that is looking like it means bizniz.
regards, al
Mark that's a great idea for the air cleaner... it looks awesome. What a work of art!!!
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Yeah wow! Your custom air cleaner mods are excellent. Very cool!
cheers, dug
1972 914-6 2.5L Gemini Blue 1973 914-6 MetalCraft Racing C-Prod/TransAm/IMSA history |
Very nice work Mark. Thanks for sharing.
All the best Henry |
Painted the stacks and it looks better. Time to finish the assembly.
Drop dead beautiful work!!!
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Stunning Mark! I love my 2.8SS on carbs, but a 3.1SS on high butterfly MFI is just nasty.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
Chain fence eating turbo
Hats off......
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
A little attention to the engine compartment. Had Kurt at Parts Klassik build a pair of their new High Voltage 6-pin CDI's for me. Extended the relay panel to accept the second CDI. Relocate the fuel filter console because of the second CDI. I'll mount the two coils just to the left of the right shock tower mount brace, just above the engine. Fairly close to what the 2.8 & 3.0 RSR's did.
![]() Installed the new 3-wire alternator and engine wiring harness. ![]() Also installed a RSR style flywheel I bought from Patrick Motorsport. Had the clutch, starter ring and flywheel balanced. ![]() Headers next.....
Installing the RarlyL8 headers. They are just over 40mm ID at the exhaust flange and then taper down to 38mm ID for the rest of the tubing. The flange's are fairly thick so there was not much of the exhaust stud visible after the washer and copper nut.
![]() ![]() Using the M&K Sport Muffler. Might be on the load side being only 26" long! ![]() Getting close now. A few other parts thrown on just for the photo and to see how things are fitting.
Schleprock
More eye candy from Mark! Nice Supertec air baffles too!!
Kevin L '86 Carrera "Larry" |
3 restos WIP = psycho
Will we be seeing this in May?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Yes you will. Maybe sooner if I can talk the rest of the Oregon Gruppe into a Washington drive day.
^^^ yes ^^^
