BURN-BROS's Avatar
3.2SS MFI twinplug....another one.
Salutations!
I thought I would share a build we are doing for a friend.
98x70.4
10.5/1 CP pistons
Stock rods w/ ARP rod bolts (balanced and resized)
MFI (72T modded for bigness)
Twinplug by yours truely
Supertec head studs
DC 40 on new blanks
You can see addition photos on Facebook.
https://www.facebook.com/BurnhamBros/media_set?set=a.864516650264122.1073741855.1000011 73857266&type=3
Cheers!
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-04-2015, 02:07 PM
BURN-BROS's Avatar
Burnham Performance
Old 08-04-2015, 04:14 PM
BURN-BROS's Avatar
The Car is a 1980 Euro SC Backdated to a 73 RSR. The MFI system we chose is from a 1972 T as it will give the customer an engine bay that conforms to 72/73 .
Throttle bodies were rebuilt in-house. Housings were bored out for 40.5 throttle plates and 38mm intake ports. All hardware was plated, housings were pickled as close to factory as possible. New custom bushings were installed. upon completion, they were Flowbenched and ready to install.
Burnham Performance
Old 08-07-2015, 08:35 AM
tharbert's Avatar
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 08-07-2015, 08:56 AM
Chain fence eating turbo
Originally Posted by BURN-BROS View Post
Awesome motor, but what is that V8 in the background?! That thing looks like a killer setup!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-07-2015, 10:20 AM
BURN-BROS's Avatar
It's a New Boss block, Aluminum Cleveland heads, and a Boss 302 Hilborn setup. It's Mocked up checking port match. If things go according to plan, it should redline around 8200 rpm. It's slated to be dropped in a old mustang I have. More pics on Facebook about the build.
Burnham Performance
Old 08-07-2015, 10:35 AM
BURN-BROS's Avatar
Fan refurbishment.
I sourced as early fan so that the Engine bay looked period. It was not in the best of shape, having moderate corrosion....but finding cherry parts is difficult.
Nasty!...but workable. I know that I will not be able to remove all signs of corrosion. After quite a bit of work, the fan is treated to the same process as my throttle bodies. The results maintain all the details that the fan had originally, and a little more "history" presevation than other methods. Not perfection, but industrially handsome.
Notice the tonal difference where a worker trimmed the flash from the parting line in the above pic.
Customer should be happy with the results.
Burnham Performance
Old 08-07-2015, 12:58 PM
BURN-BROS's Avatar
Fan shroud fitment and mocking up the MFI. Amber Fan Shroud from Damon at Series 900.
Burnham Performance
Old 08-11-2015, 02:48 PM
BURN-BROS's Avatar
Burnham Performance
Old 08-12-2015, 08:36 AM
0396's Avatar
Nice, looking forward to additional updates.
Old 08-12-2015, 08:55 AM
Hi Aaron,
Very nice looking motor!!
I was wondering if the colouring on the throttle bodies is as they came from the factory? The throttle bodies on my 72T are the same colour and I thought that they may have just faded over the years.
Cheers,
Harry.
Old 08-12-2015, 02:55 PM
BURN-BROS's Avatar
Thanks Harry,
The 72-73 Throttle bodies vary in finish from very light to almost black. I have old factory photos of the engines when new that I use for both paint markings and overall finish. Ultimately the finish will be influenced by the condition the throttle bodies are in. Same goes for any of the Magnesium parts.
Originally Posted by Harry998R View Post
Hi Aaron,
Cheers,
Harry.
Burnham Performance
Old 08-12-2015, 03:39 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
How did you "pickle" to get that nice dark grey surface? Looks fantastic.
Henry
Old 08-21-2015, 06:20 PM
BURN-BROS's Avatar
Thanks Henry. That's a secret It took a long time for me to come up with it.
I can do a warmer gold finish as well as a cooler blue finish.
The Cool finish is the one in the pic and it is corrosion resistant. Meaning that it will not grow white fuzz just sitting out, but I wouldn't soak it in water.
Wired the alternator, installed updated crank bolt, Fan belt, shroud, cam feed lines and block offs.
Burnham Performance
Old 08-22-2015, 10:24 AM
BURN-BROS's Avatar
Waiting for a few bits. Almost complete
Burnham Performance
Old 08-28-2015, 05:19 PM
That's a very fortunate friend! Beautiful work, especially enjoy the shroud color.
Old 08-28-2015, 08:57 PM
Under the radar
Trackrash's Avatar
What heads are you using? Modded SC heads?
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-29-2015, 09:39 AM
BURN-BROS's Avatar
Heads are big port 78/79. The CIS notch was welded up and drilled for the MFI injector.
Burnham Performance
Old 08-29-2015, 09:54 AM
BURN-BROS's Avatar
Just finishing up a few things on the engine today, then it's off to be installed.
Burnham Performance
Old 09-09-2015, 09:54 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Salutations!
Hi Aaron,
I had a question about how you approach the position of the injector fitting on the later head. Seems logical that the position is "centered" toward the middle/quadrant of the intake port. But is the angle just a matter of setting it such that it clears the throttle body?
At first I was thinking it could be angled just like a CIS or Motronic injector. But then I realized it would probably hit the MFI throttle bodies at such at angle.
Just trying to get a feel for how different the angle is from an MFI arrangement vs. the later CIS or Motronic.
Also, what are your thoughts on the CP pistons? Just curious how they differ from the JE usual suspect.
Kevin
Kevin L
'86 Carrera "Larry"
Old 10-22-2015, 11:12 AM
