BURN-BROS's Avatar
Originally Posted by KTL View Post
Hi Aaron,
I had a question about how you approach the position of the injector fitting on the later head. Seems logical that the position is "centered" toward the middle/quadrant of the intake port. But is the angle just a matter of setting it such that it clears the throttle body?
At first I was thinking it could be angled just like a CIS or Motronic injector. But then I realized it would probably hit the MFI throttle bodies at such at angle.
Just trying to get a feel for how different the angle is from an MFI arrangement vs. the later CIS or Motronic.Kevin
I have the angle somewhere, but I just use a factory head to quickly get my angle and position. Yes, it can hit the throttle body as it is a tight area.
Also, what are your thoughts on the CP pistons? Just curious how they differ from the JE usual suspect.
Kevin
So far I like working with them. The big difference is I have much more control in the design of the piston. I get a solid model and theoretical weights prior to placing an order. Something I never got thru J.E. Other piston manufacturers do the same thing, but getting direct feedback from an engineers can be difficult.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-22-2015, 11:41 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Thanks for confirming my suspicion & thanks for your insight on the CP pistons.
Kevin L
'86 Carrera "Larry"
Old 10-22-2015, 01:10 PM
Hello
It's often difficult to machine the plastic stacks, Did you bore them ?
Philippe
www.injectionsystemes.fr
Old 10-24-2015, 04:13 PM
BURN-BROS's Avatar
Originally Posted by philippeF View Post
Hello
Philippe
Hi Philippe,
I bore both plastic and mag stacks inhouse. These were bored 46mm top and 41mm bottom. They are matched to a set of throttle bodies that were bored to take 41mm throttle plates.
Old 10-24-2015, 04:39 PM
Nice work !
Old 10-24-2015, 04:43 PM
BURN-BROS's Avatar
Thanks!
Burnham Performance
Old 10-25-2015, 10:04 AM
pff pff is offline
pff's Avatar
Hi Aaron,
I just have to say i love your work on this engine and i want to do the samething on my 3.0!
But i like to know howmuch hp and torque this set up will generate?
Cheers,ferry
Old 01-03-2016, 01:38 AM
BURN-BROS's Avatar
Hi Ferry, Horsepower is around 280 hp depending on the exhaust you choose. With a little more cam and a little less exhaust you can see 300hp.
Burnham Performance
Old 01-03-2016, 12:03 PM
Hi Aaron,
Beautiful build. Congratulations.
I was wondering which method and media you have used for cleaning the case and all the other alloy to this brand new level ?
Cheers,
Kerem
Old 01-08-2016, 01:07 PM
BURN-BROS's Avatar
Thanks Karem,
I sub contract to a company that specializes in surface preparation. They are usually involved in the manufacturing industry and prep castings and machined parts. The service is not cheap, but the result is a very consistent and appealing finish.
Burnham Performance
Old 01-10-2016, 02:32 PM
al lkosmal's Avatar
Nice build details Aaron.....good blend of mechanical know-how and aesthetic sensibility.
regard,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-10-2016, 05:21 PM
BURN-BROS's Avatar
Thanks Al, the engine turned out very strong and is a great fit for the car.
Burnham Performance
Old 01-11-2016, 08:32 AM
Max Sluiter
Flieger's Avatar
Ooh, Mark's got a new motor? Sweet!
Old 01-11-2016, 06:47 PM
al lkosmal's Avatar
oh yessss....that looks like fun!
regards,
al
RGruppe #669
Old 01-11-2016, 07:00 PM
