Air Medal or two
Have a qulified shop check the line bore, most all need it .
The bearings for line bore are expensive and sometimes hard to find. There are several updates that need to be done I do stress need. Once all done and installed these are great engines but do not make the mistake the factory made. They ran them HOT. Too HOT
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Air Medal or two
Yes
I also recommend cam oil restrictors after break in .
Can anyone tell from the earlier photo if the exhaust is indeed 1975 thermal reactor exhaust?
What is the build date of the car? Also, the exhaust manifolds are date coded on the bottom and should be a few months before the build date of the car if they are the originals. And yes, they are not the TRs
Air Medal or two
Thermal have a very distinct look .
You have typical factory exhaust.
No thermals..
I'm hoping the non-TR exhaust is good news for head studs. The exhaust is pretty rusted, especially at the connecting points. I guess I'm wondering if it is worth salvaging since I was headed for SSI when I was under the impression I had TRs to dispose of ~ I'm guessing SSI's are still an improvement over the factory. I'll update the thread tonight with photos after I finish pulling off the valve covers and timing covers. Thank you to you both~ |
More progress:
![]() Today began with removing the oil cooler. ![]() Four nuts and it slid right out, but I was concerned about the integrity of the transmission bolts after the welded edge that was supporting the yoke disappeared. I grabbed the cherry-picker and remounted the engine, minus the spacers I had fabricated to make up the difference between the case surface and the oil cooler. ![]() The yoke was now able to be reattached to sit flush with the case. ![]() I began disassembling the right side of the motor's valve covers. When I had both covers off, I checked the torque of the head bolts. A few were loose, as you'll see in my later notes. Here's a shot of the right-side disassembled: ![]() I was more concerned with the side that had the melted-looking lower valve cover. I got both of the timing covers removed.. ![]() Right. ![]() Left. ..and moved on to the worse looking side: ![]() And, naturally, found this: ![]() ..on the middle head. Oh well.. finally, my notes to finish the night:
Air Medal or two
Yup.
Looks like you have an unmolested 2.7 and have to do the updates. and you need Hyd tensioners. Turbo valve covers if not there already. Save yourself the grief and use RSR "O" rings in the rocker shafts upon re assy.
looks like the tensioners have been molested with some sort of nut and bolt deviance
Air Medal or two
Dont be scared to replaced worn "Hooked" sprockets and the chains.
Turbo valve covers, new chain and sprockets, and RSR o-rings have been on the to-do list. I'm really trying to cover all the bases here, so thank you so much for the continued feedback. My 'fear', if there is one at this point, is not replacing ENOUGH. It'd be a real shame to take the motor apart and not do it right (like whoever was in this engine before). Now waiting on my crows foot and P202. |
Air Medal or two
My next engine will have cotton thread between case halves along with proper sealer.
Air Medal or two
You will need guides and valve work.
New plastic chain ramps. Shuffle pin case with the other updates.
Don't forget the Raceware head studs, washers, nuts. The studs are exposed and orig dilivar studs oxidize and break. With the case savers and new studs, you won't be afraid to torque the heads properly
Failure is not an option 78 SC, 06 Cayman S, 74 Targa, 1971 BMW R75, 1975 BMW R90S, 1983 BMW R100S, 2004 BMW R1200GS, 1974 Ducati 750 GT, 1974 Ducati 750 Sport, 1986 Ducati MHR Mille, 1995 Ducati 916, 1994 Bimota DB2, 2001 Tri 955 RS, 1970 Norton 750, 1975 Hon 400 F, 1971 Hon 750, 1967 Duc 250, 2016 Tri Thruxton |
Air Medal or two
They may have originated with the Carrera, IDK
Air Medal or two
Any machine shop that specialize in Porsche will be familiar with the upgrades.
You can not skimp here.
Rob
Air Medal or two
I am not sure but I think cotton swells better than silk?
It works in boats... Next, Do not follow too many aircraft procures. They are very antiquated. I have no idea why it is poo-pooed, but there is followers, leaders and get to hell out of my way people I just do what i have to do. Like i said, i can do two valves for ya and i am over next door. I have no desire to work on valves all day every day.......I am close enough to crazy already
