Do I need to check deck height on each cylinder?
As the title says- do I need to check deck height on each cylinder? I have a magnesium case which was freshly machined by ollies, new connecting rods and used however reconditioned nikasil cylinders.
Old 11-14-2015, 07:25 AM
non-whiner
mreid's Avatar
No, unless you are truly anal.
"Too much is just enough."
Old 11-14-2015, 07:27 AM
Lol- definitely not me. Thank you
Old 11-14-2015, 07:33 AM
It's a 914 ...
stownsen914's Avatar
Shouldn't be a need to check every cylinder, as long as Ollie's decked the case (or checked it at least). There can be variations in the case
Old 11-14-2015, 03:08 PM
304065's Avatar
Why not, other than spending an hour doing it? If you put it together and the cams bind because the cylinder heights are different you'll certainly check it after you tear it apart. At least measure the cylinder height, spigot height, depth of the recess in the head, etc.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-16-2015, 07:22 AM
SoyRacer's Avatar
No. Just on the one that's different from the others . . . .
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 11-16-2015, 07:08 PM
