what injector size / 79 3.0 big port EFI
I am in the process of starting a EFI project on my 79 3.0L big port.
Anyone have insight to what injector size is a good starting point?
31LB?
31lb/hr (330cc/min) Magneti Marelli (Pico) - Fox Injection
46LB?
46 lb/hr (483cc/min) Magneti Marelli (Pico) - Fox Injection
Old 01-05-2016, 06:16 PM
al lkosmal's Avatar
megasquirt:injectors [SymTech Laboratories]
here is a simple calculator for minimum size......
RGruppe #669
http://www.x-faktory.com/
Old 01-05-2016, 06:45 PM
Navin Johnson
TimT's Avatar
Yes just plug in the numbers on an injector selection calculator like the one above, or Marren has good one also..
https://www.injector.com/injector_selection_guide.html
'69 911 GT-5
'75 914 GT-3
and others
Old 01-06-2016, 04:47 AM
Old 01-06-2016, 07:55 AM
xbmwguy's Avatar
also figure in type of fuel in the equation
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 01-06-2016, 04:42 PM
Chain fence eating turbo
How much power do you plan on? Mid-20's I'd think would be plenty.
Old 01-06-2016, 04:58 PM
Do you mean Methanol of other fuels with different energy ratings to normal gas?
I don't believe Octane Rating will change the energy produced although it may reduce compression and hence the horsepower developed which will be taken into account by all of the basic calculations.
Old 01-07-2016, 12:21 AM
