'68 901/03 Engine Aluminum Case - Can Counter Balanced Crank be retro-fitted?
I have a very early 911T Engine. 2180031 . I assume this is an Aluminum Case.
This came in the '66 911 I purchased many years ago. The original Solex Engines for the '66 911 are now out of my price range.
Are all of the early Aluminum cases out of the same casting? 901/01 = 901/02 = 901/03?
Would it possible to retrofit the 901/03 Engine Case to accept a 66mm Counterbalanced Crank, and new pistons and cylinders to convert it to the 130 HP version?
Just wanting to get the full bang for the buck out of my '66 911?
Thanks.
Old 11-09-2015, 09:56 AM
yes, and 66s had webers mostly so you may be in luck!
Old 11-09-2015, 02:47 PM
Why stop at 130hp? You should talk with some experts, you'll find some here on these forums. I'm not one of them.
But my $0.02 is that I'd spend the money on cams, pistons, and reworking the heads before I upgraded the crank. Of course, once you have it down to the studs you may as well replace the crank too depending on budget.
Don't forget the oil pump and tensioners too. Pretty much you will be replacing everything to upgrade your T to normal or S specs.
andy
Old 11-09-2015, 03:39 PM
The 66 should have a counter balanced crank because the non CB crank was for the T in 68.
Bruce
Old 11-09-2015, 03:57 PM
djpateman's Avatar
Yes, engines up to 2180107 were aluminum, and the same casting was used for all models of the engine. Near the type #901/13 there should be a build # that is most likely in the 10000 range; what is that number please. A photo would be most useful.
My research is here:
Type 901/xx Engine Build #'s
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-09-2015, 04:00 PM
The number on the engine is 2180031. I can post a picture, but that is what the picture will show. So what I am understanding is the 901/03 2180001 to 2180107 were aluminum cases, with the NON-counter balanced T crank. Since I have had my green faced gauges with the higher rev limit, I wanted to go with a counterbalanced crank option. I am wondering if the counterbalanced crank bolts right in with the correct pistons, cylinders and rods?
Old 11-09-2015, 05:58 PM
Cornpanzer's Avatar
FWIW, the 901/03 I just took apart had a counterweighted crank in it.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 12-13-2015, 04:07 PM
Counterweighted Crank
Cornpanzer, What is your engine number on the 901/03? I was told by Rennsport in Portland OR, that my engine would have a counter-weighted crank.....this would be good news. I am wondering why the HP is 110, and the Rev limit is lower on this engine? Is it due to the Cast Iron Pistons & Cylinders, to reduce cost? I always thought is was due to a NON CB Crank. So with new P&C's, and Top End upgrades, I will be able to get excellent performance. Only limited by budget....
Thanks for your input.
Old 01-04-2016, 09:58 AM
djpateman's Avatar
Dan, I'm looking for the build # (~11000) stamped below the TYPE # 901/13; those under 12000 or so are the aluminum cases.
TYPE # 901/13 is the Sporto version.
Addicted since 1975
Old 01-04-2016, 11:58 AM
The 110 HP rating is partly due to the mild cams, small ports and lower CR. These engines had cast pistons which are unsafe above 6800 RPM. "S" engines had forged pistons (among other things) permitting safe operation to 7300 RPM.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-04-2016, 03:09 PM
Cornpanzer's Avatar
Here you go....
1970 911S,
RGruppe#252
Old 01-04-2016, 05:22 PM
OK, I'll check my Build Number. Thanks Everyone for all of the knowledge!!!
Old 01-05-2016, 09:37 AM
OK, I found it..... (I don't know where I came up with the 901/03....)
901/13
10359
2180031
So, I am really happy owning a 901 Aluminum Case, with CB Crank....Good Start....
Sporto Case......Any Uber Value to this???
Old 01-06-2016, 10:22 AM
