Glyco Rod Bearings (3.2 rod knock)
I just want to be sure I didn't miss anything while researching past threads on the subject.
Am I correct that the general consensus is the Clevite H 77 bearings are the best reasonably priced option for Rod bearings. Engine: 3.2 weekend warrior track use Thanks in advance for any input. Bob
85' 911 Coupe: Rebuild complete. |
Chain fence eating turbo
Clevite is the standard in the American iron engines. If I'd have known the issues with Glyco, I would have went Clevite.
It's a piece of mind thing IMO. A gamble. |
Schleprock
The reason those Clevite 77 bearings were developed by Automobile Associates is the result of problems found with the Glyco bearings. I would go with the Clevites w/out question for ANY 3.2/3.3/3.6 rebuild
Kevin L '86 Carrera "Larry" |
The last 3 sets I used were the Clevites. I asked about 3.0 Clevites and Automobile Associates told me that they were several months out but suggested and supplied me with GT 3 bearings.
Bruce Last edited by Flat6pac; 11-13-2015 at 01:50 PM.. |
Schleprock
Yep GT3 rod bearings are a direct fit on 3.0 SC rods. Very nice bearings.
Is there a discount supplier for Clevite 77 bearings ?
Try not, Do or Do not
Supertec is proud to announce that we now offer Clevite 77 rod bearings for 3.2, 3.3 and 964 in .25mm (.010") undersize. That means you can resize cranks for the best chance at success.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
When I did my re-build there was talk of faulty bearings. The suggested fix was having the Glyco bearings coated... Well as we all now know, coating them as a fix; not so much!
Oh well, live and learn. This was my first build so I am actually looking forward to tearing it down and inspecting everything. I had great help in the way of Ted Robinson looking over my shoulder a few times during the build so I am pretty confident (hopeful) there wont be any other issues than the one bearing.Anyway, I thought that would be the reply I received but I wanted to be 100% sure. As always, thank you everybody for the input. Very much appreciated!!
Crap...wish I'd seen this before I did my rebuild a few years ago...
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
abides.
Buck, the Clevite bearings have only been available for a year or so. They were released in response to the discovery that the new, non-German made Glycos were failing.
If you bought your Glycos a few years ago, it's quite likely they were still made in Germany, and are probably fine.
Graham 1984 Carrera Targa |
