Help about this cylinder marks
I'm rebuilding a 2'7 engine and I've found this marks on the wall of several cyilinders. With the finger i can not notice crackes; its completely smooth.
Can someone help? It's a symptom of material failure?
Thanks!!!
Old 11-12-2015, 10:52 AM
wdfifteen's Avatar
This should be interesting.
Is there any chance the engine sat at the surface experienced some corrosion, then the engine was run enough to polish it off? I've seen something kind of similar, though not as extensive, on cast iron cylinders.
Old 11-26-2015, 06:46 PM
Walt Fricke's Avatar
Are these Nikasil cylinders (a magnet will be lightly attracted to the surface you show with those cracks) or Alusil (completely non-magnetic)?
Nikasil is a plating, so I could see perhaps it developing cracks, though I have not seen this. Alusil is part of the aluminum alloy itself, and I couldn't see it cracking, though that doesn't mean the cylinder surface couldn't crack.
Perhaps one of the engine builders here - they see lots more stuff than we do it yourselfers do - has seen something like this.
Old 11-26-2015, 09:57 PM
SoyRacer's Avatar
Are the "shadow cracks" throughout the whole cylinder or piston height/lower position dependent per cylinder? I've seen this before.
Regards,
Rich
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 11-27-2015, 05:21 AM
The cylinders are Nikasil (checked with magnet).
According to the bills that the previous owner has given to the present owner, theoretically these cylinders/pistons are brand new with 4000 miles of use!!
I have rebuild 8 engines before and never saw this.
These "shadow cracks" are visible in 4 of 6 cylinders and more visible in the highest position of the piston.
Old 11-27-2015, 11:35 AM
non-whiner
mreid's Avatar
That looks like heat crazing to me. Did this engine overheat or was it run at high rpm for sustained periods?
"Too much is just enough."
Old 11-27-2015, 11:48 AM
I don't have information about a possible overheating. The present owner has recently bought the car and came to our workshop because the engine had oil leaks mainly at the base of the cylinders; when dismantling, the cylinderhead barrel nuts were very loose.
Old 11-27-2015, 01:38 PM
+1 I've seen similar spider crazing on flywheels where there was serious clutch plate slipping going on. Wonder what the rings look like?
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 11-27-2015, 02:28 PM
At first look the rings seem to be in good condition. But i'll check them exhaustively this week.
Old 11-29-2015, 12:31 AM
non-whiner
mreid's Avatar
This could explain the heat crazing. Extra air is like a blow torch on the cylinders. An intake leak usually burns valves, pistons, and rings. A head leak usually burns cylinders and rings.
Old 11-29-2015, 06:48 AM
Does look heat oriented.
I wonder if those cylinders were bored and re plated or is it original Mahle nikisil plating.
Old 11-29-2015, 11:01 AM
Try cleaning them up with a Scotchbrite hone. See what they look afterwards.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 11-29-2015, 03:11 PM
I'll try what happens with Scotchbrite. Also to check if the cylinders are brand new as customer says, according to the invoices that the previous owner gave to him or if they have been replated.
Old 11-30-2015, 10:21 AM
After analyzing the cylinders with Porsche specialist and leader workshop of Barcelona, the conclusion ist that the aluminium under the Nikasil coat is beginnin to cracke. So, there are not reusable. Nobody can identify the origin of the problem...
Thaks for your opinions
Old 12-03-2015, 12:36 PM
Sorry, for a bad explanation. It seems that a reaction between the aluminium and the Nikasil cover has produced; and the NIKASIL not de ALUMINIUM is beginning to cracke.
Old 12-04-2015, 01:35 AM
Photos made with magnifiing glass
Old 12-04-2015, 01:37 AM
I recently found Nikasil delamination a brand new, unused 90 mm Mahle Nikasil cylinder. A local experienced 911 engine builder told me that he has also seen this. It seems that their current plating process may have some issues. I had mine re-plated by Millennium.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 12-04-2015, 03:10 AM
