plans for a six motor test stand
would any one have some plans or pictures of a flat six test stand for running/tuning a motor outside the car?
thanks steve |
Its not really difficult: you simply need to replicate how the engine is mounted in the car, add an oil tank, appropriate oil ines, cooler w/fan, and a flywheel with ring gear and starter. Naturally, a fuel system is needed thats commensurate with whats in your car.
An empty transmission case will help make this all possible,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Do a search on YouTube for "Porsche Engine test". These are several good examples.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
stand
Here's a couple of pix for you. The 1st two pix are from a previous Pelican post., that I saved,..I thought that is was a good example of what I'd like to build. The 3rd pic is an engine test stand, that I am currently using, that was designed for V8's, that I modded for the 911. I bought it as Costco for $300 or so, several years ago. Not as elegant a design as the other shown, but It works very well.
Good luck with your project. regards, al ![]() ![]()
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
big thanks AL it looks like a great design, strong and simple
I have thought about this many times, even discussed the design with Grady. But, unless you are building it to accomodate a dyno of sorts to put a load on the motor, all you will be able to do is tune it for idle and make sure it doesn't leak......
![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
what is the down side to running the fixed hubs and brakes for a "poor" mans dyno
(it might help to get readings for emissions although estimating load would be difficult) What is the aprox weight of a 3.0 engine and 901? Last edited by pete-stevers; 11-17-2009 at 07:31 PM.. |
Less brakes, more gas!
In the classifieds there was a fellow selling setups with housings to put the starter on and mate to the engine. They were not very expensive!
-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
A product that does exactly what you want is available from Engine Test Stand for Air-cooled Porsche and VW or from Pelican Parts online catalog.
I am the manufacturer of these engine test stands. Contact me if you have any questions or would like to get one! Tom 858-243-0476
Anyone know what happened to these test stands in blue above? When you click the link, only the engine adapter rings are available now...
