Max Sluiter
What is the issue with the cable? I'm in the design stages of a midengine project and am probably going to end up with a cable shifted 914 trans and a cable throttle due to ease of routing. I'm using a Tilton floor mount pedal box and it's center seat so the Porsche linkage is completely out.
Is the cable ok for track but not rally cars or if the run is made straight enough can it be made reliable?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Chain fence eating turbo
There's a large cable for my throttle from the factory on my 87. As long as a quality piece, shouldn't be a problem.
i think trumpets without the manifold would pip it for peak power, but the carbon airbox apparently isn't that far behind and is simply better everywhere else in the rev range. The car was a front runner in period.
![]() the modelling is complex, which is the reason i assume rothsport don't bother developing their own- they use the factory GT3 plenum as a model, porsche did the research, which makes sense. the airbox above did not have GT3's around as an inspiration when it was built, but the research seems to be sound, as the results were convincing haha. My understanding is it isn't just about presenting cold air but providing a large reservoir of air post filter, helmhotz resonance, etc. i've actually got an E36 M3, factory ITB's.. would be interesting to do a test with plenum on/off with trumpets Last edited by clutch-monkey; 01-11-2016 at 02:18 PM.. |
I've kicked the idea around for some time to try casting a set of throttle bodies for a 911.
The concept below consists of a tapered throttle body which can package up to a 50mm diam throttle plate. The inlet side features at least a DCOE 45 bolt pattern (or up to 70mm between fasteners for a larger throttle plate). Independent base idle adjustment via a screw actuating the throttle plate. A throttle linkage (not shown) similar to the triumph units. ![]() I fully intended that these could be used with a common plenum or individual runners. I choose a short EV14 injector from an LS3 as they are easily (and affordably) available with all the injector characterization data. For a direct to head design, there is a real challenge to balance the position of the injector due to the 3.2 and earlier head stud pattern. It is obvious why Porsche chose to change to the later 964/993 design. |
![]() Quote:
I no longer run open ITB's on a street weight car as a result. The bonus for me was being able to use larger panel filters not socks or K&N. i'm not an engineer though, so can only go off results on mine or friend's motors ![]() Probably not worth the bother. If you had to, adapt or copy factory stuff would be your safest and most cost effective bet surely? Last edited by clutch-monkey; 01-12-2016 at 04:36 AM.. |
We have looked at the various ITB and their manifold arrangements and there is huge variation. The Jenvey appears to point directly at the wall of their inlet manifold as does the Borla 3003. If you want to replicate the injector position that Porsche uses on the early MFI and other systems then you will need 3 separate throttle body castings which is a pain. The RSR with high butterfly throttle bodies used the injector in the air trumpet and many modern motorcycle systems use twin injectors which seem interesting but are complex and costly. Throttle plate position also seems to vary significantly and again it is difficult to quantify the influence of this variable without a great deal of work. When I started this thread I hoped to be able to find some numbers that could point the way to differences due to this type of change but there don't seem to be much hard data available. I have just asked for a quote for castings and will see just how expensive it is to make a start. The direct to head design may be OK to machine from solid or may be 3-D print which could be interesting. |
My Jenvey's are attached to a 12mm phenolic resin spacer. I was told it is to limit heat transfer from the head. The engine is not running yet so I don't know how these ITBs perform.
Thanks, Paul 1979 SC "A man of many projects and too many hobbies" |
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
While the temperature in the engine bay is not as bad, thanks to the fan, you also have that same fan disturbing the air, the 911 engine bay is basically a huge airbox, having a separate airbox with a dedicated intake eliminates this interaction. That said, in powertrain development, using 1-D models to optimize torque and BSFC is cost effective and expected, but I don't think the business case is there for the aftermarket, too much work for too little benefit, specially in an engine without cam phasing, fixed lift, fixed intake length, and fixed trumpet length. |
I always believed that Air Filters smooth the flow of air around the intakes and that this can and often does help in a 'busy' under bonnet environment. The question is how much more improvement is there to be gained by using a 'box'.
What I am less certain of is the extent of any pulse effect in terms of cylinder filling. Inside one of these boxes must also be quite busy as the pulses and pressure waves will potentially interact and cause problems but I imagine that these problems can be minimised with careful design. There are many good SAE papers on this subject which seem to suggest that Air Box resonance occurs in a very narrow frequency window and has a small impact on pressure - around 10 millibars is a typical quoted value for the air boxes used on F1 cars which I would expect to be quite good. The conclusions that seem to come out of the published work is that airboxes only provide horsepower benefits in narrow rpm bands depending on their specific design but that they are very useful in filling in 'holes' in a powerband that can arise due to poor general airflow. With the ITB design we are planning to use the only practical measurements we will be able to make will be 'open' intakes with simple trumpets, rain hats with ITG foam elements to replace the K&N filter and a stock 'Weber' Airbox. I hope it will be an interesting comparison. |
![]() The interesting thing about the Jenvey design is that they have a product which is very universal, it can be applied across various engines with success. Alone, however, it is not optimized. The injector position is a compromise with respect to packaging and injector angle relative to gas flow. The idea is to maximise mixing of fuel with the air intake charge and minimise wall wetting. I choose to also minimise the distance from the injector to the intake port and place it after the throttle plate to increase the system response. In my experience packaging dictated a number of design attributes, these are not necessarily optimized but a balance of engineering requirements. I also prefer a design which implements a common airbox and resonator plenum. BTW do you know what the nominal distance is between the intake ports (cross car)? |
SuperFlow
Hi, Chris
Great discussion here and have been following along. I have an interest in this subject but no practical experience, that would add anything to the discussion. To teach myself Solidworks, I did an air cleaner assembly as little design project. More for style than performance but it did lead to a little bit more in depth look at the possible theoretical performance improvement. Pendulum Outlaw, Build, Adventures and Misadventures Link to the air cleaner page During the summer I picked up a SuperFlow SF600 flow bench. I am deep into house renovations, right now, but I will throw this offer out there, if anybody wants to design and build the test fixtures, and gather the parts for a test, I would be happy to put them on the flow bench and test them. I have cleaned the bench up as it was in storage for a number of years. Computer seems to work but I have not run a calibration test yet. Low priority for me and as a first off test learning project, I plan to have a 3d printed bell mouth made to compare to the exiting velocity stack.
Outlaw .... by definition ..... does not follow rules well www.FloydDesign.ca https://www.youtube.com/watch?v=sV5aIALWlG8 |
It is very narrow, and very engine specific, the flexibility has been greatly benefited with adjustable intakes, but is not an easy thing to do with an old engine. However, it would be interesting to measure the effect of using a varioram intake setup in the same engine. |
Turbonut
I am in the process of replacing the throttle cable on 911 altogether in favour of E46 M3 elctronic throttle actuator and will test if two actuators work on the same output to get rid of linkage too.
Synchronizing between banks can be done with adjusting the actuator arm, no problems there. VEMS ECU that I use can easily control the electronic throttle..
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
Turbonut
It operates exactly as OEM drive-by-wire system with dual pedal sensors (PPS1/PPS2) and dual throttle sensors, one for throttles (TPS1) and one for the motor position (TPS2).
I can create multiple profiles (progressive response etc) to improve driveability in traffic etc. Used the same system on E46 M3 with electronic throttles+double-VANOS. In fact there are nothing too bad making DBW, just source some ETC pedal that suits best to 911 (almost any of them works, 99% of them have PPS1/PPS2) and attach throttle actuator motor. I will just use the dbw control on regular ITB's.
Hows this project going Chris?
