LinkBack | Thread Tools |
Rating:
UnRegistered User
Been following this for quite some time. Glad to hear that you had some help to get it figured!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
abit off center
Im going to have a cigarette and I dont even smoke
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Fred is the bomb!! That's my Targa that he's doing the engine rebuild on. Congrats on getting your problem sorted.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
Glad you figured it out....
I've found the Porsche community to be just like Fred -- roll up the sleeves and "How can I help"... I'd have a whole lot less (interesting) cars (and less interesting stories) had there not been the forums and subsequent local Porsche greasers around..... cheers, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Carrera tensioner install update........
It was decided to replace both Carrera hydraulic tensioners and replacement parts ordered from Pelican parts. I was informed by PP Sales that the tensioners would be arriving August 22 (Friday) of last week. On Saturday (August 23), FedEx rang my door bell and left a note. By the time I opened my door, the delivery guy was driving away from my house. I have been waiting for this important package and another delay.
Called the FedEx about the DTN (door tag number) and asked if they could contact the driver for me to get the package. I was told they have no contact with the driver. So I asked which FedEx Depot could I go to pick up the package? Since I did not have a tracking number only a DTN tracking the package was not that simple. So I asked when is the next scheduled delivery and was told on Tuesday. Why Tuesday? How about Monday? FedEx does not do residential delivery on Monday (Tue. to Sat.). I waited on next delivery because signature was required for package valued more than $500 according to PP sales guy. To make the story short, got the package on Tuesday and installed them the following day (Wednesday) but ran out of time to do a test run. Today (Thursday), I was ready for the test run. Disconnected the CDI and removed the FP relay and cranked the engine several times to lubricate the engine and primed the tensioners. I was a little bit anxious to hear the sound of the engine. The knocking noise from bank 1-2-3 was gone!!!!!! But what was that noise coming from? Bank 4-5-6 was making aloud rattling noise that was not there before. I removed the chain housing cover for bank 4-5-6 to do another inspection. This could not be another failed tensioner because it is new. Just a few minutes old. Removed the chain housing cover and looked directly at the newly installed Carrera tensioner. It has failed and collapsed!!!!! After removing the tensioner, I could press the piston with my fingers. A sure sign of a bad tensioner. What have I done to deserve all this punishment and frustration. To get over my frustration and disappointment, I went over to the other section of my garage and retrieved an used/old Carrera tensioner from another engine I am rebuilding and installed it on this 'stubborn motor'. With a new tensioner on the left side and a borrowed old tensioner on the right side, cranking the engine (not running) produced the sweetest sound I've been longing for a long long time. End of story. Moral of the story: Fresh from the box expensive parts are defective. Who are making these products any way? Would Pelican parts replace these defective products? Only time will tell. Now, I could go to bed and sleep well. The culprit is now identified and just another work day tomorrow. Tony |
Picture of the old and new hydraulic tensioners......
Forgot to post the picture of the hydraulic tensioners .
![]() If these new Carrera hydraulic tensioners are really this bad, how long do we expect them to last compared to my 20-year old hydraulic tensioners purchased before the advent of the Internet. Tony |
Incredible. Moral of story - assume nothing. Could have been a lot worse.
Tony - tried to PM you last week - on 930 FD supply line. Your PM inbox was full. New piston rings these days are already beyond spec at install. Almost better to keep the old ones in. Things ain't what they used to be. Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Under the radar
These oil fed tensioners are an enigma for sure.
How is the air bled out? Just put them in and hope they work? Porsche says if you can depress the plunger while prying with a screwdriver, replace it, it is defective? I have a thread about them here, maybe what you learned can be added.Carrera tensioner questions
When you got the new tensioners did you prime them first? I got a new one from pelican, put it in a bowl of oil, and pulled the pin. It sucked in oil as it extended. I compressed it, installed the pin, and repeated the cycle a couple of times. Ran fine
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
3 restos WIP = psycho
This is why I use freshly rebuilt 930 tensioners with collars.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
+1......This is my preference, as well. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
can al or kenikh post a pic and p/n of such tensioners you recommend... thx
I live for 911 tweaks... |
Member 911 Anonymous
Yes, purty please
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Remove the bleed screw (plug) from the body, then introduce shop air pressure into the opening. I heard a rush of air, then felt the internal ball valve move into position. I reinstalled the tensioner, primed the engine and the plunger pressurized as designed. It's been fine for 15 years. Or.... since you just acquired them, try the above and if unsuccessful, return it for a replacement tensioner. Sherwood Sherwood |
930 tensioners w/collars
Found these pix by googling...Not too much to see here.....just standard 930 hydraulic tensioners with safety collars.........(hydra-stops).
![]() ![]() regards, al
My tensioners needs to be replaced - can the 930 tensioners be fitted to an 87 car, if so are there any downsides?
The 930 tensioner so are still expensive, then you need new oil lines and chain covers.
There shouldn't be any problem with the Carrera tensioners, I think Tony bought all the defective ones...... Bruce |
lol
Bruce, I totally disagree with your statement. I think I got one (1) good one (knock on wood) and a bad unit. Remember, I was just cranking the engine and have not run it long enough to say that the Carrera hydraulic tensioners are satisfactorily good and acceptable. With all the bad lucks and unforgivable blunders I was having with this rebuild, I have not lost faith because all of you guys were behind me and giving moral support except for a weird individual. The good news today is that Pelicanparts has advised me to contact their Customer Service to replace this failed unit. I will keep my finger crossed and hope to get a good one this time. Thanks. Tony |
Thanks Bruce - only asking as this would be the 2nd pair of replacement tensioners to be fitted to my car so looking for a more long term solution
