TWJ TWJ is offline
TWJ's Avatar
2.2 E engine rebuild question...
I need to bore out the standard size cylinders on a 2.2 E engine that I am rebuilding...what are the options for repair sized pistons? What is typically done?
Source for the replacement pistons?
Thanks much!
Old 02-23-2016, 04:03 PM
Check with EBS, engine builder supply,in Nevada.
Bruce
Old 02-23-2016, 05:21 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
X2 EBS. Higher compression pistons is a nice upgrade
Chris
Old 02-24-2016, 07:57 AM
bgyglfr's Avatar
85mm JEs. I'm assuming 2.2E cylinders are birals?
70T 2.7RS spec.
68L coupe
Old 02-24-2016, 12:47 PM
TWJ TWJ is offline
TWJ's Avatar
bgyglfr,
Excuse my ignorance but what do you mean by "birals"?
Old 02-24-2016, 04:51 PM
Max Sluiter
Flieger's Avatar
Originally Posted by TWJ View Post
bgyglfr,
cast iron bore liners with aluminum fins cast around them. Used on street motors until Nikasil came out (race engines used Chromal which had hard chrome plated bores).
Old 02-24-2016, 06:54 PM
bgyglfr's Avatar
Yes. Biral cylinders came stock on a 2.2E. They are good candidates for boring and using JE pistons. You can order JEs to your specifications.
70T 2.7RS spec.
68L coupe
Old 02-24-2016, 07:57 PM
tharbert's Avatar
Once bored, you can have nickel-silicon plating (Mahle's Nikasil) added to your cylinder bores. Maybe someone who knows more can wade in but I don't think it adds very much at all to the tolerances and provides that extra level of protection. I had Supertec add nickel-silicon plating to my new brial cylinders. I think they contract it out so maybe contact Henry Schmidt for more info.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 02-25-2016, 09:12 AM
bgyglfr's Avatar
US chrome does it. I want to say it was either $75 or $90 per cylinder. I just remember when paired with a set of JEs, it was a very reasonable.
70T 2.7RS spec.
68L coupe
Old 02-25-2016, 05:34 PM
