Intermediate shaft timing chain gear replacement.
Apologies if this has been thrashed before but my search yielded nothing.
Trying to removed the rear timing chain gear from the intermediate shaft. Removed the big circlip, and it looks like it just slides on with a woodruff key, but even with a bit of heat and a puller it won't budge. Any tips or things I'm missing?
I have a replacement (this one's missing a few teeth) on another shaft with the same problem.
The workshop manual is silent on the subject also!
Mick
Old 03-14-2016, 09:24 AM
tharbert's Avatar
Encouragement
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-14-2016, 09:29 AM
Excellent thanks
Old 03-14-2016, 10:15 AM
Well tried all that - MAP gas for 10 minutes+, puller pulled up as tight as I dare, even a bit of penetrating oil ..... but no joy. Any other ideas? Please...
Old 03-15-2016, 03:06 PM
VFR750's Avatar
What size puller? I have the big craftsman one with the forged arms. Pulled them off.
Probably you have some galling or corrosion on the mating surfaces.
Actually a few heat and quench cycles might help break the bond.
Old 03-15-2016, 03:23 PM
I used a press and it came right off
Old 03-15-2016, 10:37 PM
All done. The penetrating oil overnight might have done the trick, but a bigger puller had it off both the old and replacement assemblies without any heat, and the new one on the original shaft with the press, again without heat. Thanks to all.
Mick
Old 03-16-2016, 08:39 AM
