SSI installation - broken exhaust headstud
Hey everyone. I was removing the stock heat exchanger on my 79 SC as part of an SSI installation and 1 of the head studs broke at the level of the heat exchanger foot - it sheered off when I turned the nut.
I'm really disappointed that it broke as I was hoping for the best when I started the job. I guess the fact that it didn't break at the level of the head is a plus but still a little uncertain as to how to proceed. What are the best options to remove the stud? Vice grips? As I do have a fear of breaking the stud off at the level of the head, maybe I should install the SSI and drive the car to my mechanic who may have more tools and options at his disposal. Thoughts?
You got plenty of room - vise grips, but first, plenty of heat around the stud. Let the heat do the work, keep testing the stud with the grips til it wants to move moderately easily.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
UnRegistered User
Can you thread on a nut?
If so, I would try to double nut it (sounds painful) and back it out. If not enough room for two nuts, thread one on and plug weld it to the stud. The heat from welding might get it loose from the head. Or borrow a stud collet the correct size. Lots of options with that much stud sticking out from the head. Start soaking it with your favorite penetrant before trying anything...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
its not going to unscrew, save yourself the aggravation. be patient and acquire the drill jig/guide that is made for this purpose. youll have to dremel the stud as flush as you can get to the case then install the jig and drill. when its done the bad threads come out as a wound wire.
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
+1 on Vise Grips!
Spray some PB Blaster on it, let it sit for a bit and have at it with the vise grips. Hope you can get it off!
1971 911T Irish Green Coupe |
ROW '78 911 Targa
MAPP gas is your friend. Get it red hot before using vice grips or double nutting or whatever. Cherry red....
Or mig a nut on it.
Air Medal or two
Listen to the HEAT advise.
And straight propane is not near enough.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Gee that's a lot of heat.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
Air Medal or two
That will do it , if a person is not all that savvy with a torch, you can improvise a heat shield with some scrap sheet metal .
Heat the stud, , soak it, do it again. Somewhere in there it will jump out (almost ).
forget the pb blaster comments, it snapped because it is bonded in there good . get one of those map/oxygen kits from lows, it has a pencil tip point with it. heat the stud until it is cherry red and get the vice grips on it . this will be relatively easy as the heat will ll go down in the stud and there is no exhaust to sap away the heat .
the other option I would consider is screw on a nut and tig weld it on the top . the heat alone will probably do it but then you have a "bolt" to work with .
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Thanks everyone. I tried the double nut technique but was unsuccesful. It's a tight spot to get both wrenches. I think the heat application is a little outside of my comfort zone. I lack the equipment and my car is on a ramp, not on a lift. I'm gonna take the car to my mechanic for this one thing.
I do want to thank everyone for all of their advice. This forum is an awesome place. |
maybe have it towed on a flatbed to your mechs faster and easier
81 sc 3.0 turbo wb coupe |
I would heat the surrounding metal around the stud rather than the stud itself. You want to accomplish two things:
- Melt any locking compound on the stud threads - Expand the aluminum to create space for liquid thread penetrant (suggest Kroil) Applying torque to a heated fastener may cause it to distort. Wait until it cools a bit before applying loosening torque. Then repeat the above several times. You want to avoid breaking the stud flush with the head if at all possible. Double nuts (or a weld-on nut) provide a more secure grabbing area than locking pliers in that confined working space. Sherwood |
Broken stud removal
What 911Pcars said. Don't heat the stud, heat the head. The best place to heat is inside the port right next to where the stud is threaded into the head. I replaced all of the exhaust studs when I rebuilt my SC engine using this method. Everyone came out easily. I used one of the Mapp gas type torches and a stud remover tool. You will want to heat the head, try turning the stud. If it doesn't move, repeat the process. All that heating the stud will do is to weaken the stud, causing it to break again at the surface of the head. Then you will have to do the drilling process!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
I rebuild engines and have to deal with this all of the time....so I use stud extractors...and heat.
this and this...... and this......... 1982 Porsche 911 SC Coupe - Engine Rebuild Wizard - Page 6 These allow you to get into a tight spot, like the exhaust stud that you are showing in your pic and they work very well, if combined with heat. Note: the cheapies from ebay are surprisingly good quality for the low cost. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 04-10-2016 at 09:58 AM.. |
Weld a nut on it and while it is red hot crank it out.
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
I've never been faced with this particular treat, but every "use heat" comment aimed at *head* studs recommend heating the surrounding metal, not the stud. Dunno why this would be any different.
Making the stud OD larger doesn't seem like what you'd be looking to accomplish...
'90C4 |
Return oil lines orientation........
PB, Are your adjustable return oil line tubes correctly installed? The larger diameter end of an adjustable return oil line should be on the crankcase side and by looking at the picture you posted they seem otherwise. In other words, they look like they were installed backwards. Keep us posted. Thanks. Tony |
Hi everyone. Thanks for all of the advice. This proved to be a bigger job than I anticipated. With the exception of the broken headstud, however, things went really well. I removed the air pump system, swapped out the oil lines, installed the SSIs and installed the new muffler. So with 5 of the 6 nuts in place in the passenger side, I'm gonna drive it to my mechanic, have him take off that SSI and fix that stud. I'm comfortable with my limitations and it shouldn't cost that much for him to do it.
Anyone want to tell me a horror story that makes me tow it in rather than drive it in? I've been around the block and it runs great. Tony, I'll ask him about those oil line tubes. It's possible the previous owner put them on incorrectly. You are right about the orientation. Thanks again for everyone's advice and support. PB
