arbita1's Avatar
Broken Fin on Head
My first rookie mistake in my engine rebuild. During removal of the heads from the cam tower I was having trouble separating them. I should just kept tapping the top of the studs. But I tried to tap the bottom of the cam tower with a rubber dead blow hammer and caught a piece of the fin on the head. It broke off as you can see below.
My intuition is that it's still reusable. But maybe I'm being hopefully optimistic. Do I need to replace this head.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-11-2016, 05:39 PM
abit off center
cgarr's Avatar
A clean head will do more for cooling than that one corner fin:
______________________
Craig
G2Performance
Old 04-11-2016, 05:51 PM
Broken Cooling Fin........
Matt,
The broken piece from the cooling fin is negligible compared to the total surface areas. It will not affect the cooling charactics of this cylinder except for some mental anguish for the mishap. Once this cylinder is installed, it won't be visible anymore and you will forget about it. I think the accumulated dirt on your engine would have a more adverse effect than the missing piece.
Tony
Old 04-11-2016, 08:27 PM
Straight shooter
Lapkritis's Avatar
Easy access for having someone weld it back on if it really bothers you. Then grind flat.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-15-2016, 08:13 AM
0396's Avatar
If he wants it " perfect ", simply buy another head to replace it.
Old 04-15-2016, 09:52 AM
arbita1's Avatar
This is not concours. I just want to make sure it's functional. Once I install it, it'll be forgotten.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-15-2016, 01:59 PM
Try not, Do or Do not
Henry Schmidt's Avatar
That missing fin will have no effect on cooling. Cosmetics count but as the owner you choose.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-15-2016, 02:55 PM
