Broken Fin on Head
My first rookie mistake in my engine rebuild. During removal of the heads from the cam tower I was having trouble separating them. I should just kept tapping the top of the studs. But I tried to tap the bottom of the cam tower with a rubber dead blow hammer and caught a piece of the fin on the head. It broke off as you can see below.
![]() My intuition is that it's still reusable. But maybe I'm being hopefully optimistic. Do I need to replace this head. Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
abit off center
A clean head will do more for cooling than that one corner fin:
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Broken Cooling Fin........
Matt,
The broken piece from the cooling fin is negligible compared to the total surface areas. It will not affect the cooling charactics of this cylinder except for some mental anguish for the mishap. Once this cylinder is installed, it won't be visible anymore and you will forget about it. I think the accumulated dirt on your engine would have a more adverse effect than the missing piece. Tony |
Straight shooter
Easy access for having someone weld it back on if it really bothers you. Then grind flat.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
If he wants it " perfect ", simply buy another head to replace it.
This is not concours. I just want to make sure it's functional. Once I install it, it'll be forgotten.
Try not, Do or Do not
That missing fin will have no effect on cooling. Cosmetics count but as the owner you choose.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thread Tools | |
Rate This Thread | |
