-   -   Disassembly Done ... Time To Rebuild 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/909871-disassembly-done-time-rebuild-3-0-a.html)
2jmotorsports 05-06-2016 08:50 AM
Subscribed. Subbed all the 3.0 L rebuild threads. :D
Also good luck!
arbita1 05-06-2016 08:57 AM
Thanks.
Picked up my polished crankshaft yesterday. I'll post some pics later. Now I am waiting on the replacement wrist pin bushings to be delivered and then I will drop my rods off next to be re-bushed.
I'm pretty psyched. Yesterday when I was at the machine shop, he showed me two sets of 911 heads that he was working on. This is not a Porsche specific shop and I had only planned on giving him stuff that was more generic (crank, rods, cleaning, etc.) I told him I didn't realize he did these and he told me they do them and have been getting a lot for some reason lately. And his price was in line with other shops who do this. I was dreading having to pack up my heads and ship them. Now I think I can drop everything off with him. Glad I stumbled upon this yesterday.
arbita1 06-28-2016 05:08 PM
Progress has been super slow. Machine shop took forever with my rods. But I started to get stuff back and hopefully now will have some progress.
Crankshaft micropolished
http://uploads.tapatalk-cdn.com/2016...8fad81eebc.jpg
Rods rebushed
http://uploads.tapatalk-cdn.com/2016...c4c20549d9.jpg
Case hot tanked
http://uploads.tapatalk-cdn.com/2016...06070c16d0.jpg
Cam towers hot tanked
http://uploads.tapatalk-cdn.com/2016...75f0503bf7.jpg
One problem. When I removed the oil pressure relief bolts and springs I didn't take out the piston piece inside. One fell out so the shop found it but the other one got hot tanked inside. It's stuck now. Any ideas on how to remove? It's the one in the right side case.
http://uploads.tapatalk-cdn.com/2016...5aa1b136b9.jpg
gtc 06-30-2016 03:07 PM
Magnet?
arbita1 06-30-2016 05:14 PM
Apparently there was a part in Wayne's book that tells you to make sure you get the Pistons out before you hot tank your case as they will get stuck in there. Oops. I had to pop it out through the passage on the other side. I couldn't find anything to fit in there and then used my sons target arrow from his bow set to knock it out.
cgarr 06-30-2016 06:37 PM
A 1/4 pipe tap works good to grab those pistons too:
Trackrash 07-01-2016 09:55 AM
A strong pair of circlip pliers works.
Forrestkhaag 07-05-2016 11:47 AM
This thread is most helpful in gaining insight into my 3.0 tear down and subsequent build. Thanks for the pictures and conversations from all involved. Here we go!
arbita1 07-15-2016 06:31 PM
Some progress...finally. Got the crankshaft together. On to case assembly now.
http://uploads.tapatalk-cdn.com/2016...3a5c80b319.jpg
Forrestkhaag 07-18-2016 10:16 AM
A thing of beauty!
jess p 07-22-2016 09:12 PM
911sc rebuild
Nice job. I have an 81 911 sc that I'm just started the same process. Ordered
the P 202 and 203 tools. That's what's holding me back
arbita1 07-29-2016 07:55 PM
Trying to figure out all the locations that require epoxy It's a little hard to tell from the photos in the book. Is this one?
http://uploads.tapatalk-cdn.com/2016...92610e43c4.jpg
Mark Henry 07-29-2016 10:12 PM
Yes, but take care not to over do it as the fan sits tight against it.
arbita1 07-31-2016 01:41 PM
I was making progress today.
http://forums.pelicanparts.com/uploa...1469997581.jpg
http://forums.pelicanparts.com/uploa...1469997617.jpg
But then.
http://forums.pelicanparts.com/uploa...1469997646.jpg
I'm hoping heat and a stud remover will get this out. :(
mikedsilva 07-31-2016 02:17 PM
Wow...
surprised that stud broke off.. the oil pump nuts aren't torqued that tight are they?
I'm doing a 964 engine at the moment too..
When you got your case back from being hot tanked, what other prep did you do to get it super clean?
Also, did you removed the sealant from the flanges or did the shop do that for you?
Cheers
Mike
al lkosmal 07-31-2016 03:25 PM
I've not seen one of those break before.....but a good stud remover, heat and PB Blaster are your your friends.
arbita1 07-31-2016 05:26 PM
Originally Posted by mikedsilva (Post 9221476)
Wow...
Cheers
Mike
I used carb cleaning and shop towels. Followed by isopropyl alcohol with Kim wipes. The hot tank took off most of the old sealant. What was left I used a scotch Brite pad and carb cleaner to remove the rest. Also I found that goof off and a razor blade works well for removing stuck gaskets.
arbita1 07-31-2016 05:27 PM
Originally Posted by al lkosmal (Post 9221552)
I've seen one of those break before.....but a good stud remover, heat and PB Blaster are your your friends.
For some reason it wouldn't click on the torque wrench so I kept going and then snap.
arbita1 08-01-2016 06:05 PM
So the good news is this stud did not put up any fight. A little pb blaster and a stud remover. Didn't even have to use heat. Now waiting for the new stud. The PET shows the stud as a m8x20. But when I enter the part number it comes up as a m8x37. Not sure which is right.
cgarr 08-01-2016 06:28 PM
Some show grip length after installed and some parts list show over all length.
I think pelican shows overall length at least they do with exhaust studs
Sent from me
