IF your going to run a IR system you will need the capabilities of the XFI. If you are using a MAF style efi intake the EZ Fast system should work better for that.
I know what an ITB is, but what's an IR?
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Puny Bird
tbitz is just one option, I believe it's just a 911 sorted Megasquirt (MS) system that come with a base (fuel values) map And most of the bits needed in a well thought out package. These items can be bought separately (or fabricated) for any efi system you choose to use, just depends on your skill level. A EFI system is just the brain and harness you still have to add the injectors, some of the sensors, fuel pump, regulators, lines, intake, etc. All systems need a certain amount of fab work, mostly welding bungs and adapting sensor mounts. Many suppliers also can put together a kit like tbitz, at the same time many don't. Some that don't offer kits have dealers who do install systems into specific cars. Most other systems also have map examples, so in other words a base fuel value map. SDS comes with a base map, they ask you about your app when you order, but also has a 3.2 and a 930 map examples on their website. MS has many map examples on the MS forums. A base map is just a rough fuel values program (think carb jetting) to get your tune in the ballpark. Prices for systems range as cheap as $500 for south africa's Gotech MFI to well over tens of thousands for a pro tuned and installed MOTEC. All systems will also require a wide band O2 meter, but that is a good idea even for tuning carbs.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
"I know what an ITB is, but what's an IR? "
IR = intake runner or individual runner Last edited by boosted79; 05-01-2016 at 11:31 AM.. |
Slippery Slope Expert
As long as we're in the dictionary mode, what's an "SDS?"
Chain fence eating turbo
Simple Digital Systems, an EMS manufacturer.
Puny Bird
Some I mentioned.
http://sdsefi.com/ Gotech MFI X Megasquirt started as a DIY kit MegaSquirt | Premier DIY EFI Controller You can buy Megasquirt as a DIY kit right up to pro built units Suppliers - Megasquirt EFI This guy has experiance doing complete MS system for the VW crowd he may have a 911 engine under his belt The Dub Shop There is also a very long list of other EFI manufactures TEC, Haltec, Weber, Autotronic, Motec just to name a few. And may parts suppliers, PMO, Jenvey, goingsuperfast....again it's a big list. Competition Engineering makes a complete 911 system I believe based on the TEC system.
Puny Bird
EMS = Engine Management Systems
Most systems do much more than just FI, they also can do ignition, boost control, fans, pumps, variable timing, data logging, etc., so they truly are EMS systems. You can build a system to just do FI or very complex. Lots of jargon to learn
Straight shooter
Vems is one of the best value ecus even price wise compared to megasquirt. The wideband controller on board makes the difference.
http://vems.us
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 05-02-2016 at 02:48 PM.. |
What systems have the best auto tune functions? I hear Haltech and Electromotive had good software for this. It seems like 90% of the battle with EFI is just getting the thing to run right so it can be fine-tuned.
That's a concern of mine too. I will be installing on a never before run engine so I don't need issues in making it run/get an initial tine during that phase.
Puny Bird
The SDS will run right from first start and for break-in it has a simple rich/lean mixture knob like on an airplane. So using your wideband you simply turn the knob to a safe AFR like 12.5:1 during your break-in. Then you can use it to tune your system with the pendant as you drive. I use an old ashtray as a mount and can program (tweak) the system, alone as I drive, in about an hour. BTW many tech savvy dudes didn't like the old SDS because of it's simple pendant programming system that you couldn't hook a laptop into. Pretty sure you can tune with both the pendant or laptop now with the new versions. This is my first temporary SDS pendant ashtray mount from back in 2003. Knob on the right is the rich/lean mix knob.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 05-03-2016 at 07:40 AM.. |
There are a ton of options out there, that's for sure. Many are very good, and they keep increasing the features to make cars more driveable. The biggest key is to find and use the one you are most comfortable with.
Holley, FAST, and AEM are top notch. I went with Pantera EFI (Also branded by Weber Redline, and 034 Motorsports) for our 356 build. I chose this system because at the time, and maybe still today, they were the only ones that let me run full sequential injection without a cam sensor. The Pantera EFI uses a faster processor, which allows the crank sensor to be used to determine which stroke the engine is on. The tuning software, and documentation are more difficult to understand than with the Holley or FAST, but beyond those hurdles, it lets you do a ton of stuff. It will work with MAF or MAP, has comprehensive blending between alpha-N and speed/density tuning, and plays well with wide-band oxygen sensors.
1960 356 Super 90 - EFI'd 1989 190e 2.6 1991 964 |
3.2 intake is a great way to go, IF you can find one for a good price. 930 and EFI conversion guys buy them up, as well as 3.2 guys keeping them for their rebuilds. If anyone has a line on one for cheap send mb911 and me the info (maybe we can both do a DIY thread on a 2.4 and 2.7 conversion).
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
Has anyone ever used a 3.6 intake? I ask because I have a few of those laying around. What is the advantage of the 3.2?
I had planned on using the SC intake or ITB's, but am open to other options. |
All are plastic, unfortunately. The aluminum version us quite rare, having been used only the first year of the 3.6, and maybe not all of that. We have three, only two (and maybe one) are available.
I would rather be driving
The 3.6 intakes have better flow uniformity compared to the 3.2 intakes. Additionally there is a resonance chamber controlled by a flapper valve to change the VE characteristics as a function of rpm.
I would be interested in a plastic version if you are selling. I think Cory (Tippy) and I have the same idea here.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I will need to consult with my partner on selling and a projected price.
What controls the flapper valve? (Since we were removing them for our manifold we never really paid much attention.). I'm guessing a combination of manifold pressure and electronics.). Since the electronics will be absent in my proposed use my thoughts were not to worry about that feature. My main concern was port size. This would go on a 3.0 SC with the early boing port heads, which I believe (off the top of my head) are 38mm. How would that match up with that intake? (All this I would have discovered, but since we're talking about it . . .) |
