Engine won't turn
Posting on behalf of a friend of mine
His car is a '76S with a 2.7L
Was running strong with no issues. In fact it had about $8k spent on it just before he bought the car
Drove it to a mechanic to drop the engine/gearbox to start body Resto
Now trying to do tappers but engine wouldn't turn at all. Neither clockwise nor anti clockwise
He removed gearbox and starter. He pulled off cam gear cover to inspect. He removed sump and stuck a snake camera up its guts. He removed spark plugs and had a good look
Nothing looks sinester but still engine won't turn
If it has something major broken, you would expect it to at least move a little in either direction then stop
It only sat for 2 weeks so surface rust inside barrels couldn't be an issue. He sprayed WD40 anyway
Still it won't budge
Any suggestions?
If he bolts starter back on and try to turn it over a fraction, would it be a bad idea?
Thanks in advance
Rafik
Old 06-02-2016, 12:28 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Did he try loosing all the valve adjusters? What position is the cam shaft in? Without the plugs there should be no pressure, very strange.
In the $8K work, what was done? Head machined? Maybe they were no square and cause the cams to warp?
Post a pic?
'85 Carrera Targa
PCA/POC
Old 06-02-2016, 12:45 AM
pete3799's Avatar
So the engine is on a stand? Check for interference from the mounting yoke.
Pete
79 911SC RoW
Old 06-02-2016, 02:34 AM
Yes, all plugs are off
Definitely no interference
No, didn't try to loosen adjusters
will ask him for a couple of pics and post
Keep in mind, this was running perfectly till it was pulled out
Got me stumped
Old 06-02-2016, 02:42 AM
Old 06-02-2016, 03:41 AM
Very strange indeed. Yes, tell us what 8k in work was done. That has to involve some major surgery. How many miles were put on it between that work and now? The way I see there are two possibilities. One, the engine was very tight after being put back together and the guy was turning it over with a breaker bar to do the timing. It may run ok for a while in that condition but I'd think not for long. Two, something happened during the last engine drop, hard to believe though. I don't think I'd bolt up the trans and starter to bump it until more investigation is done, eg. loosening all the rockers.
Old 06-02-2016, 05:48 AM
DRACO A5OG's Avatar
I kinda see engine is sitting on a dolly of some sort? He verified clearance from the fly wheel.
+1 do not put a starter to her, it may sheer off the bolt mount on the fly wheel or worse fractured a cam shaft.
'85 Carrera Targa
PCA/POC
Old 06-02-2016, 10:50 AM
Any updates?
Old 06-04-2016, 06:51 AM
If it was running then why is the induction removed.
Old 06-04-2016, 07:11 AM
I don't know if this pertains, but what is that blockage in the return tube?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 06-06-2016, 07:42 AM
Straight shooter
Lapkritis's Avatar
Last time someone posted one of these they had bound their flywheel against the engine stand.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-06-2016, 01:13 PM
I'd check end play on the crank as a next move.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 06-07-2016, 08:10 AM
VFR750's Avatar
Originally Posted by lapkritis View Post
last time someone posted one of these they had bound their flywheel against the engine stand.
+1
btdt.
Old 06-07-2016, 01:29 PM
No joy. Heads are now off. two barrels have some scouring on them. Still not turning. Sound like he has to go the whole way and split the case
Old 06-13-2016, 03:49 AM
DRACO A5OG's Avatar
oh poop
So, is that oil return tube crushed?
'85 Carrera Targa
PCA/POC
Old 06-13-2016, 01:50 PM
Should know more in the next few days, will post an update
Old 06-13-2016, 04:57 PM
Cairo94507's Avatar
Please keep us posted.
'71 914-6 #0372
'17 Macan GTS
Old 06-14-2016, 07:03 AM
Straight shooter
Lapkritis's Avatar
Yes- interested in what the culprit is. Engines don't normally drive in and suddenly lock up. Heads off and still bound is bizarre for a runner that drove into the shop.
Old 06-14-2016, 08:00 AM
safe's Avatar
I hade a 2 liter mag case engine that was like this. It needed a very large force to break loose then it would turn, let is sit for a while it was solid again.
Turned ut to be a bad rebuild, engine case was warped and gripped the crank. Needed tons of work and money...
Magnus
Old 07-07-2016, 12:20 AM
tharbert's Avatar
Originally Posted by safe View Post
...engine case was warped and...
I wonder if the $8k rebuild included $2k+ of machine work most mag cases need. In the one pic of the case, it doesn't look it was hot tanked anytime recently.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 07-07-2016, 06:24 AM
