Engine won't turn
Posting on behalf of a friend of mine
His car is a '76S with a 2.7L Was running strong with no issues. In fact it had about $8k spent on it just before he bought the car Drove it to a mechanic to drop the engine/gearbox to start body Resto Now trying to do tappers but engine wouldn't turn at all. Neither clockwise nor anti clockwise He removed gearbox and starter. He pulled off cam gear cover to inspect. He removed sump and stuck a snake camera up its guts. He removed spark plugs and had a good look Nothing looks sinester but still engine won't turn If it has something major broken, you would expect it to at least move a little in either direction then stop It only sat for 2 weeks so surface rust inside barrels couldn't be an issue. He sprayed WD40 anyway Still it won't budge Any suggestions? If he bolts starter back on and try to turn it over a fraction, would it be a bad idea? Thanks in advance Rafik Last edited by karmannghia60; 06-02-2016 at 12:30 AM.. |
Member 911 Anonymous
Did he try loosing all the valve adjusters? What position is the cam shaft in? Without the plugs there should be no pressure, very strange.
In the $8K work, what was done? Head machined? Maybe they were no square and cause the cams to warp? Post a pic?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
So the engine is on a stand? Check for interference from the mounting yoke.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Yes, all plugs are off
Definitely no interference No, didn't try to loosen adjusters will ask him for a couple of pics and post Keep in mind, this was running perfectly till it was pulled out Got me stumped |
Very strange indeed. Yes, tell us what 8k in work was done. That has to involve some major surgery. How many miles were put on it between that work and now? The way I see there are two possibilities. One, the engine was very tight after being put back together and the guy was turning it over with a breaker bar to do the timing. It may run ok for a while in that condition but I'd think not for long. Two, something happened during the last engine drop, hard to believe though. I don't think I'd bolt up the trans and starter to bump it until more investigation is done, eg. loosening all the rockers.
I kinda see engine is sitting on a dolly of some sort? He verified clearance from the fly wheel.
+1 do not put a starter to her, it may sheer off the bolt mount on the fly wheel or worse fractured a cam shaft.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-04-2016 at 11:02 AM.. |
Any updates?
If it was running then why is the induction removed.
I don't know if this pertains, but what is that blockage in the return tube?
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Straight shooter
Last time someone posted one of these they had bound their flywheel against the engine stand.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I'd check end play on the crank as a next move.
Rusty 71 911E 55 PreA speedster 85 Turbo look Cab 62 Twin Grille Roadster (getting close) |
No joy. Heads are now off. two barrels have some scouring on them. Still not turning. Sound like he has to go the whole way and split the case
oh poop
![]() So, is that oil return tube crushed?
Should know more in the next few days, will post an update
Please keep us posted.
'71 914-6 #0372 '17 Macan GTS |
Straight shooter
Yes- interested in what the culprit is. Engines don't normally drive in and suddenly lock up. Heads off and still bound is bizarre for a runner that drove into the shop.
I hade a 2 liter mag case engine that was like this. It needed a very large force to break loose then it would turn, let is sit for a while it was solid again.
Turned ut to be a bad rebuild, engine case was warped and gripped the crank. Needed tons of work and money...
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I wonder if the $8k rebuild included $2k+ of machine work most mag cases need. In the one pic of the case, it doesn't look it was hot tanked anytime recently.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
